Author Subject: coil pack removal
shabusta
Is this an XSI thing an Australian thing or just a phase 3 thing.
How do you remove the coil packs? or do i need to remove the brake fluid reservoir?
Posted 19th Jan 2016 at 09:24
should be able to just rock engine forward enough to get access to the coilpack cover bolt
Posted 19th Jan 2016 at 10:21
alcon
or use an Allen key bit in combination with a ratchet spanner or open ended spanner. A bit of a faff but can be done easily enough
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 19th Jan 2016 at 10:28
shabusta
All bolts removed from the cover, yes the bolt under it was a right belend, but now i cant get the cover past the metal part of the resovoir without possibly (?) Damaging the coils.
Posted 19th Jan 2016 at 10:30
alcon
Cover should get past the master cylinder without having to remove it. XSi engine looks slightly different but should still wiggle off to reveal coil packs.
1999 Rallye (black)
Posted 19th Jan 2016 at 10:43
shabusta
after fiddling some more.... i have to remove the strut brace?
Posted 19th Jan 2016 at 11:35
demondriverdan
Probably, yea. I remember having the same problem before which is why I don't bother running a cover anymore.
Rallye Race Car
Posted 19th Jan 2016 at 13:01
You will need to remove the strut brace, yes.
Posted 19th Jan 2016 at 15:12
Isn't xsi 1 twin coil running wasted spark joined all together? But yes remove the strut brace first or no chance on an xsi.
Posted 19th Jan 2016 at 15:39
jimmyhackers
i have an xsi.... tis more fiddly than the gti as the coil packs are built into the cover....
but it can be done without removing athinythign else.
tis quite fiddly to wrangle off and even fidd;lierr to wrangle back on but not undoable
Posted 19th Jan 2016 at 18:07
