Author Subject: Russain Guy top mounts coloured
Just had my Top adjustable mounts Anodised ...ready for the front dampers end of next week Crazy
Posted 29th Jan 2016 at 09:02
mocinim
Very nice very shiny Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 29th Jan 2016 at 09:07
Won't be for long LOL
Bit Sad really but only had it done to stop corrosion long term Whistle
Posted 29th Jan 2016 at 10:48
mocinim
Should hold out for a while longer in any case and its a good feeling fitting shiny bits seems so much more worth while
Posted 29th Jan 2016 at 11:00
mocinim
My latest effort white !! (dont know dont ask)
mocinim has attached the following image:
Posted 29th Jan 2016 at 11:06
Chr1sch
Nice! I take it you are cutting larger holes in the turrets then? - I'm assuming there is no point with adjustable top mounts without coilovers? (i.e. B8's?)
Posted 29th Jan 2016 at 11:35
not enough room to move a standard spring around.
Posted 29th Jan 2016 at 11:46
As Welshpug said can't & no point ...yes have to cut & also use 15mm front wheel spacers with longer stud conversion as per Russain Guy has ...because Coilovers dampers are threaded down nearly to Droplink ARB bracket ..v long Eibach Coilovers springs with
Progressive springs fitted as well & tires touch the springs otherwise ..
Posted 30th Jan 2016 at 07:49
Whites a great colour .....that's all you will have soon sadly ...a photo of how it did look ......nice job though Thumbs up
Posted 30th Jan 2016 at 07:51
mocinim
Cheers sub frame arb are also in white the car is not for regular use dry days only probably pugfest and other days out
The astor maybe my car for daily or track or both
Posted 30th Jan 2016 at 08:46
