| Author | Subject: Advice- GTI6 running on dta s40 ecu |
davis100
Newbie Location: HOLYHEAD Registered: 22 Nov 2012 Posts: 30 Status: Offline |
I have a standard engine gti6 with magnet exhaust and de cat running dta s40 management a single coil pack and normal ht leads, I've had it mapped but it's a nightmare to start when cold, struggles to turn over pops and bangs and starts eventually if the battery has not gone flat, it won't idle when cold and has a misfire low down in their revs, when warm tho it starts like a dream and runs fine through their rev range, is this normal? Does it need to be mapped better? Is there anything else wrong? |
needs the cold start map tweaking a bit by the sound of it.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
davis100
Would that cause the missfire also? |
stan_306gti6
Why have you changed to a single coil pack and/or running with a DTA with a standard engine with only an exhaust as a modification? It seems a bit overkill, but as Welshpug says, your issue is the cold start mapping.________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
RallyeP6
Regular Location: West Byfleet Registered: 11 Jul 2013 Posts: 451 Status: Offline |
If it struggles to turn over and the battery and starter are good, sounds like you have too much advance while cranking. There are settings for cranking the engine over before it fires and starting tooth/position degrees. |
Take it ASAP to a good mapper !Before you do some real damage .... |
Send me the map.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
rikky
put a virus in it which steals his bank information every time he gets in the car with his wallet________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
It's tricky to get a 100% superb cold start map if you've driven it somewhere to be mapped as it won't be stone cold.I'm running the same and in the cold, a bit of throttle when you start it and holding the revs up for 10 seconds or so works for me. If I don't it will die or rev lumpy. ________________________________________ ![]() |
rikky wrote: put a virus in it which steals his bank information every time he gets in the car with his wallet I was gonna make it voice controlled so you have to shout 'Rikky's a c**t!' to start the car. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
fatlapit
mines rubbish too, but 650 injectors and scatter spark just cant seem to make her idle until shes warm________________________________________ |
Shouldn't be an issue unless the injectors are particularly poor quality.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
fatlapit
Had them tested by the manufacturer and by a specialist. Theyre fine. Only other thing is to raise the base pressure and hope it sorts it________________________________________ |
fatlapit
Tbh my mate matty has the same issue on his 205 gti6 turbo. Maybe the idle stratergys on omex are rubbish.Saying that it will start and idle. But if you blip the throttle it will just cut out and not catch the idle ________________________________________ |
Throttle enrichment and/or the tipout/fuel cut settings need tweaking.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
fatlapit
Cheers bud________________________________________ |
