displaying posts 2651 to 2675 of 3424
Pages (137): first .. 106 [107] 108 .. last
blandy
Post #2651
Nice, is that unit smaller than the Corsa set ups?
Posted 7th Jun 2020 at 11:27
Post #2652
Sadly ...I’ve discovered Titanium Blue bolts ..small insignificant update really Crazy
Bonkers and no Advantage I know Thumbs down
Posted 13th Jun 2020 at 17:28
Post #2653
That’s not the actual one Mike as that’s £5k but 4kgs ...
The one I’m looking at is 5kg and yes both much more compact smaller than Corsa Thumbs up
Posted 7th Jun 2020 at 14:38
blandy
Post #2654
Nice, I like my Corsa unit but downside is that it is fairly bulky
Posted 7th Jun 2020 at 15:34
Post #2655
This ones not got all the metal around it and uses a smaller motor also ..sadly all of them are bulky really Mike Thumbs up
Posted 8th Jun 2020 at 19:11
Post #2656
DTA Dash now has a peaked 3D printed sun visor LOL
Posted 13th Jun 2020 at 17:24
Post #2657
Post #2658
Bought myself a little 1:4 drive (Teng tools) torque wrench 4-25 to check and use on my bells / rotor Fixings and other small items that need low torquing up ....
Got a 3/4drive and 1/2drive for the wheels Whistle
Great quality products for the money and they last well Thumbs up
Posted 13th Jun 2020 at 17:23
Post #2659
Big important update
Need my power steering back because my Citroen Mk1 -2.4 quick rack is beating the SH-T out of me at Prescott and Combe
So ——Finally bit the bullet and ordered a BCE Pro EPAS power steering kit ...basically it’s a purposely made setup similar to the Corsa B EPAS in a nutshell ...has it’s own ECU That can be configured if required on a laptop as well as 5 standard assist settings and off switch ...
I’m building a space type frame for it off the roll cage and bringing it much further back to the seat...
Post #2660
Post #2661
Received the EPAS power steering kit
Must admit it’s bloody expensive but is very well made ....let’s hope it works as good as it looks ?
It’s all programmable on a laptop if your into tinkering Whistle
I’ll just be using the 6 adjustable turn switch settings for now
Posted 13th Jun 2020 at 17:22
Post #2662
Two very large fixing screws ..
I’ll make a plate to come off of the dash roll cage with a space frame type system with some nice big Holes in the metal to save as much weight as possible
The motor unit looks like a Renault one removed from a car and rewired ?
Post #2663
Today I removed my Fibreglass lightweight race dash And all the standard loom around the steering column...
Wow is that lot heavy Crazy
Post #2664
The steering Column wasn't light ether
y
Posted 13th Jun 2020 at 17:21
Post #2665
Old Triangle Steering Column Support bracket wasn’t to bad and I may use that again ?...may !!!!!
Post #2666
Never put the triangle support bracket onto the floor with the bit getting binned as I may cut it about and reuse it again
Post #2667
All Clear and nearly ready for project power steering and column manufacturing Whistle
{Also I can now upgrade my rollcage to my strut tops}
Posted 13th Jun 2020 at 17:20
Post #2668
Just got to cut out and grind flat the old Pedal support bracket either side of the Good ridge x3 together hoses in the Middle of the picture Thumbs up
( should have plenty of room around the floor mounted pedal box after ...hopefully LOL )
Post #2669
Serviced the old Citroen MK1 2.4 quick rack today had it apart and cleaned all the old grease out and put new grease inside and fitted x2 new boots at the same time ...much smoother and with the old WD40 nozzle the new boots bellow in and out without sucking or ballooning either way now
Had to fettle down a little of the alloy ram bracket which I don’t use because I dropped the engine 25mm it just touched a little ....
Fitted the Rack again and now onto making a new steering column to fit my EPAS .
Posted 14th Jun 2020 at 19:25
Post #2670
Posted 14th Jun 2020 at 19:26
Post #2671
Posted 14th Jun 2020 at 19:27
Post #2672
Posted 14th Jun 2020 at 19:29
Post #2673
Posted 14th Jun 2020 at 19:30
Post #2674
Posted 14th Jun 2020 at 19:31
Post #2675
WD40 nozzle used below new boot to stop sucking and balloning when hot / warm on track Thumbs up
You can see the effect and feel the difference when cold after moving the steering fast side to side in the vice ....
So say old BTCC trick on CV boots all over the car
Posted 14th Jun 2020 at 19:41
