displaying posts 2701 to 2725 of 3424
Pages (137): first .. 108 [109] 110 .. last
Post #2701
The picture makes the steering column look off centre ... it’d not the column it’s the picture honest LOL
Posted 21st Jun 2020 at 07:28
Post #2702
Been busy today ...think I’ve broken the back of it now Thumbs up
Posted 21st Jun 2020 at 22:29
Post #2703
Removed the plate and re-angled it and beefed it up to stop flex = Twin skin x2 3mm plates with built in washer
Posted 21st Jun 2020 at 22:32
Post #2704
Cut the intermediate lower connection down and welded and drilled opposite sides and pinned as well as spot welded the ten pins in for extra safety
Posted 21st Jun 2020 at 22:36
Post #2705
lower intermediate UJ joint will have a Spherical bearing on it to pull it back right out the way like with me holding it in this picture
Notice NO triangle steering or pedal support being used anymore
Posted 21st Jun 2020 at 22:39
Post #2706
Excuse the cable tie LOL
Needed to hold it as I only have a UJ correct size at mo and it will change to picture on next post ...and UJ will be removed behind steering wheel
Posted 21st Jun 2020 at 22:43
Post #2707
Pictures below will be used to instead of UJ
Posted 21st Jun 2020 at 22:52
Post #2708
Posted 21st Jun 2020 at 22:55
Post #2709
Posted 21st Jun 2020 at 22:56
Post #2710
It was Hopefully 2steps forward ? but just had some news of one back sadly Thumbs down
Update input shaft behind steering wheel now fixed as in pic and I have the 19mm = 3/4 tube to go in it also ...got SWG /2mm wall thickness =CDS & I bought 3.2mm /SWG also ...
I need to design and then get cut out the support frame for the input /steering side column...I have a idea in my head
This flaming river steering linkage Stuff isn’t cheap but the quality is wow ...
https://www.flamingriver.com
The only one problem now is my Lifeline (new Weld on )quick release Boss won’t be made or available for 4months ....
No pic of it available yet only bolt on below ...
Totally new design like Rapfix Japan stuff where the wheel can go on upto 100degrees out of line and self centre but no adaptor needed for Momo 70x6 PCD unlike Rapfix stuff
https://www.oldhallperformance.com/lifeline-products-quick-release-steering-boss/high-angularity-
Posted 23rd Jun 2020 at 15:05
Post #2711
Posted 23rd Jun 2020 at 15:03
Post #2712
Posted 23rd Jun 2020 at 15:04
blandy
Post #2713
Looks good Damien 👍
Posted 23rd Jun 2020 at 21:23
Post #2714
blandy wrote:
Looks good Damien 👍
Thanks Mike Thumbs up ...
I’ve decided tonight I’m going to cut the floor side out and move the seat more towards the tunnel like in Your car because now my elbows are far to close to my door bars and I have only spot welded the PAS so I can move it easily over a couple of inches ...Whistle Crazy
Had a bad day today sadly had to visit Apple store as my phone screen smashed to bits luckily I still had 3months of Apple car still cost me £79 for a phone worth £1400
Posted 23rd Jun 2020 at 23:23
Post #2715
Thank god someone mentioned (GO RACE) quick release 70 PCD ..(Weld on)
Visited them today and bought one off the manufacture = £188.94 inc vat and free delivery...
Much cheaper than all the other Self alignment ones I’ve looked at and a sample blue one was available it’s very small and compact Thumbs up
Posted 24th Jun 2020 at 19:53
Post #2716
Posted 24th Jun 2020 at 19:55
Post #2717
Posted 24th Jun 2020 at 19:57
Post #2718
Posted 24th Jun 2020 at 19:58
Post #2719
Hopefully now I can get the 210mm long x 19mm round 3.2mm CDS tube machined down to 17.5mm and get it welded on now for the weekends play about LOL
Happy now as I can progress Whistle
Posted 24th Jun 2020 at 20:02
Post #2720
the first pics out of the split mould of my centre console ....needs trimming and sanding and clear coat Thumbs up
Posted 25th Jun 2020 at 22:51
Post #2721
Steering wheel input shaft made and just needs Tigging up Thumbs up
Posted 25th Jun 2020 at 22:54
Post #2722
Plenty of room behind the pedals now Whistle
Just the 19mm Spherical bearing support to sort
Posted 25th Jun 2020 at 22:56
Post #2723
A few updates
Sump spacer for my PACE dry sump to move the crank away from
The PACE dry sump and limit oil Froth and soak and drag Etc ...so say a mod it needs ???
Posted 27th Jun 2020 at 16:56
Post #2724
(Started something today )that I’ve wanted to do since I saw and bought the Satchell car that Mike Bland now owns and he has made a hell of a weapon ...
I cut the inside Exhaust tunnel out around the drivers seat which has enabled me to move the seat towards the passenger seat and that has made the pedal box line up 95% now and i can now un-spot weld the power steering and move it towards the passenger side 50mm giving me much more right arm / door bar room ...plus the big difference is I was able to move the seat back 50mm :..
I’m making a steel 90degree angle piece up to weld back in tomorrow ..
In pic steering wheel got to still be moved but the dash still fits with PAS fitted
Just got to make up tomorrow a temp cardboard steering support template and the get it Laser or Plasma cut out and bent
Posted 27th Jun 2020 at 17:00
Post #2725
Dash temp fitted to see what works and doesn’t LOL
Posted 27th Jun 2020 at 17:10
