displaying posts 2951 to 2975 of 3424
Pages (137): first .. 118 [119] 120 .. last
Post #2951
Push the UK one on the outside of the French one
Posted 21st Nov 2020 at 15:49
Post #2952
So basically it’s now got a angle back but the original lip is still on it to fit the front section from France
Posted 21st Nov 2020 at 15:51
Post #2953
Posted 21st Nov 2020 at 15:52
Post #2954
So from a side view it looks like this with the pushed on new angled back on far right ...
Posted 21st Nov 2020 at 15:54
Post #2955
The block of would is the same as the Satchel trumpet length and the are completely different to normal satchell ones ...made for Sandy by Satchell for the engine...they fit flush inside the Airbox
Posted 21st Nov 2020 at 15:58
Post #2956
Pleased it’s all level the same as the engine and Inlet now
Posted 21st Nov 2020 at 15:59
Post #2957
Posted 21st Nov 2020 at 16:00
Post #2958
Posted 21st Nov 2020 at 16:01
Post #2959
Happy with the fit
Posted 21st Nov 2020 at 16:02
Post #2960
Now both part have been roughed up and bonded with VM100 two pack bond from Easy composites
Posted 21st Nov 2020 at 16:04
Post #2961
Plenty of clamps used ....it’s dry in 30mins but fully cured in 24hrs
Posted 21st Nov 2020 at 16:07
Post #2962
Tomorrow I can release the clamps and then tape up the outside and smooth more Black VM100 two pack around the outside edge to make it look as per original French one then x4 coats of PU lacquer the whole rear section to protect it and so it matches the front end ....
Then just a little more messing about with the Mk 2 dash Thumbs up
Posted 21st Nov 2020 at 16:11
Post #2963
Been bonding new ends on my mk2 dash which is going to be used as a mould ....
Out of the clamp and bonded together....Also taped up both sides of the rear maxi inlet box and smoothed and blended it in a per original from France with VM100 two pack black bond ...really pleased with it and it came out much better than I expected Thumbs up
Just needs a hand sand with 360grit padded paper = light sand down to get a key and let the 4 coats of clear coat -PU UV 2pack spray
Yellow marks are for trumpet locations
Posted 24th Nov 2020 at 16:28
Post #2964
Last ever photo of the mk2 dash ...it was delivered to be moulded Thumbs up
Hopefully in this pic you can see how much more curved into the driver the centre bit is
Posted 25th Nov 2020 at 20:50
Post #2965
Nice work Thumbs up
Posted 25th Nov 2020 at 20:41
Post #2966
prism7guy wrote:
Nice work Thumbs up
Big thank you Steve ...any updates your end mucker ?
Posted 25th Nov 2020 at 20:49
Post #2967
Sorry promise this is the last photo before the mould ...he’s already filled and spraying it tomorrow getting ready for making the mould ...he’s fussy and likes it right LOL
Posted 25th Nov 2020 at 20:53
Post #2968
Collected my Trumpet/ Rear Airbox support billet bracket
Posted 26th Nov 2020 at 18:27
Post #2969
Overlapped to lock together as my Satchell trumpets are fixed
Posted 26th Nov 2020 at 18:29
Post #2970
Posted 26th Nov 2020 at 18:30
Post #2971
Flush fitting trumpets on the inside of the Airbox rear and the Support bracket is outside
Posted 26th Nov 2020 at 18:32
Post #2972
All I can say even with 50mm Diamond drill bits and Perma-Grit Dremel bits this Carbon fibre / Kevlar composite is a nightmare to drill and smooth and stop fraying Thumbs down
Posted 26th Nov 2020 at 18:36
Post #2973
These are worth every penny and it’s the best purchase from Autosport show to date for composite work Thumbs up
Perma-Grit Dremel bits Course .
Posted 26th Nov 2020 at 18:40
Post #2974
Once I’ve got my Maxi Air-box fixed which will hopefully be by Saturday I will then start modding my bonnet to close around it ...
I’ll remove the inner twin skin underside that touches the air box when closed ... the green masking tape is ontop to give me a guide and try it ...then if needed make a slight bulge and shape the bonnet ready to have a single skin Carbon one made with support bracing underside ..
This one will be used for a new mould
Posted 26th Nov 2020 at 18:48
Post #2975
I stripped the engine that was in goldie last week, the top piston ring in each cylinder has chipped and lost some of its coating. I'll upload some photos this weekend and update my project thread, luckily the bores appear to have survived. Pretty sure my coolant temperature being so high has been a big factor in it and there's also signs of detonation which i think is what actually killed the rings.
Good luck with bracing a single skin bonnet, mine was comical when i didn't have my middle aerocatch and aluminium stiffeners bonded in, it was wild above 100mph Laugh
Edit: Once again, top work Thumbs up
Posted 26th Nov 2020 at 20:16
