need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets.
| Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #3051
needs a number square on the door for sure ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
eiei0
Regular Location: Kildare Registered: 08 May 2020 Posts: 193 Status: Offline |
Post #3052
Don't fancy doing a lid for a standard battery box do you Damien I'm sure that is long gone on your car ![]() Keep up the good work, during these strange times I thinks it great to have an interest that gives me something to do around the house, that also gets me out of the house if you know what I mean, |
Post #3053
welshpug! wrote: needs a number square on the door for sure 100% will be |
Post #3054
eiei0 wrote: Don't fancy doing a lid for a standard battery box do you Damien I'm sure that is long gone on your car ![]() Keep up the good work, during these strange times I thinks it great to have an interest that gives me something to do around the house, that also gets me out of the house if you know what I mean, I sadly don’t do the Carbon of fibreglass It’s mot something I would want to get involved in as the mould is silly money from my guy .... Thank you |
Post #3055
When you think you had thought of all the crazy ideas for your car and then get sent this to make my Maxi Motor Sport box 4WD I’m not running silly power as mine is N/A .... Great bolt on idea though... |
Post #3056
Just weighed the first made Fibreglass one 3.3kg ...it feels super lightweight |
Post #3057
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Post #3058
Day666 wrote: When you think you had thought of all the crazy ideas for your car and then get sent this to make my Maxi Motor Sport box 4WD I’m not running silly power as mine is N/A .... Great bolt on idea though... ![]() Nice idea but silly amounts of work! When u due to be finished Damo?? ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
Post #3059
jeffers wrote: Day666 wrote: When you think you had thought of all the crazy ideas for your car and then get sent this to make my Maxi Motor Sport box 4WD I’m not running silly power as mine is N/A .... Great bolt on idea though... ![]() Nice idea but silly amounts of work! When u due to be finished Damo?? Yep 500 horses min needed to make up for the extra weight and no advantage for what I do I’d like to Hope Lee this sort of time next year 12months only because of the Engine upgrades and Sandy No rush with the craziness at mo and it’s got to be right |
Post #3060
Test |
Post #3061
Lots going on at mo ...sadly the Mrs dad passed away with Covid and I’ve been working late and long weekends away ..First time I’ve had a chance to get out and work on the car ... Cut the bumper Radiator vents out and sanded down the edges ....as you may know it’s made of Carbon Kevlar mixed weave and I can tell you that Kevlar is a nightmare to cut / sand ... |
Post #3062
I ended up leaving the frayed ends and mixed some clear Two pack epoxy and painted it on the frayed edges and I’ll sand them down when dry tomorrow |
Post #3063
Getting there ![]() |
RallyeP6
Regular Location: West Byfleet Registered: 11 Jul 2013 Posts: 451 Status: Offline |
Post #3064
Good work, yes that Kevlar is hard to sand and finish. Hey you got the same Dremel as me. |
Post #3065
RallyeP6 wrote: Good work, yes that Kevlar is hard to sand and finish. Hey you got the same Dremel as me. Hi Rouben Have seen you on here for a bit ? Yep really pleased with it and the flexible extension....sadly it started sounding funny and slowed down ..think I nearly over heated it yesterday with the Permagrit bits .... I clear epoxied all the edges and lightly sanded the edges today ...it’s the only way to seal and stop fraying Kevlar I’ve found |
Post #3066
Update but Nothing very exciting Some of you may or may not of noticed that in post (3063) -two posts back -that the Grill support tabs on each side didn’t have the half round shape like the centre has ? This was because I thought the centre one would be enough but on fitting it to the car and almost standing on it to see it flex the left and right flat tabs in the grill I didn’t cut out made a massive difference over the prototype we did the same to .... Basically I’m trying to get away without using any support rods on the splitter and if I have to only two ... Close up pic below of the sides and uprights missing ....no half rounds |
Post #3067
Want them to look like this ...remember this had only just come out of the mould and the grill areas been cut |
Post #3068
So I bonded some letter C -cut in half Carbon rod and bonded them on |
Post #3069
I can hopefully start tidying it up and filling a few areas etc ...I personally think -it’s the little details that all add up to make the difference .... |
Post #3070
Mocal 7.6 Litre Dry sump tank which is splittable and I have the fitting bracket also |
Post #3071
Not been on for a bit because works so busy and I’m doing 12hr days and 10hr weekends sadly ...Anyway decided to have a play with the bonnet cutout around the Maxi Air in take . The bonnet needs to be approxly = 1inch higher under side and with being a twin skin bonnet means the outside will have a slight bulge and shape which hopefully if it works out correctly will blend into the rest of the bonnet ? First thing first ruin a good bonnet |
Post #3072
Secondly try it on the car |
Post #3073
Thirdly WTF have I got myself into now |
Post #3074
You can’t really see from the pic below but the tapped orange /reddish centre is approx 1inch higher now Dont panic -keep calm and just work my way through it step by step and I need to order more Body filler to get the blend and shape 100% Also order loads more Epoxy and Fibreglass matting for making the shape so I can remove the raised centre once the fibreglass is dry ....it needs to have 4-5 layers of fibreglass matting Plenty of work to do yet ![]() |
Post #3075
Well here we go a metal temp frame to support the cutout middle and it’s all the right height now ![]() |
