| Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
blandy
p-silva21
Regular Location: Lisboa Registered: 26 Jan 2012 Posts: 160 Status: Offline |
Post #852
Hi Damien!That´s an absolutely awesome project... that engine looks amazing Really like to see your updates! Cheers from Portugal |
Post #853
demondriverdan wrote: How are you going to do the Aerocatches? I've still got to do mine at some point although it doesn't have hinge mount points like yours which makes it a bit more tricky! I'm going to do mine the same as blandy & my green race car Ross is buying ...sadly not got a clue how you would fit a non hinged one Dan |
Post #854
p-silva21 wrote: Hi Damien! That´s an absolutely awesome project... that engine looks amazing Really like to see your updates! Cheers from Portugal Thank you Pedro ...the Sandy Brown Engine is so usable power wise .....it's insane ...but I'm really not far off finishing it for this year m8 ....tailgate fitting & spraying ....satchel shift sorting & tweaking ....oil change again (still) using MOBIL 1 semi 10/40 ....heated Windsreen wiring in on the now redundant rear heater switch |
blandy
Post #855
Day666 wrote: demondriverdan wrote: How are you going to do the Aerocatches? I've still got to do mine at some point although it doesn't have hinge mount points like yours which makes it a bit more tricky! I'm going to do mine the same as blandy & my green race car Ross is buying ...sadly not got a clue how you would fit a non hinged one Dan Actually mine was a single skin and had normal style catches ontop like this ![]() Damien how was your temps on track with 10/40 semi? I changed mine to 10/50w fully synth just from reading on here seemed the preferred option so maybe i didnt need to as mines just a basic engine, but guessing you have a fairly hefty cooler? |
Post #856
Blandy ...you've posted a Block pic m8 It's a unused Engine ...only run in on the Bench Dyno & I was told by Sandy that I have to use Semi 10/40 for next 3 oil changes & use a Genuine Peougeot oil filter at all times as it helps oil pressure The temps at Combe for 10 odd laps at a time were Oil Max 95-99 Water Max 85-90 Don't forget I've got open circuit sandwich plate NO thermostat & 19 row oil cooler .. Plus my water Thermostat has 20 holes drilled out by Sandy all around the outside of the metal ..but I have no metal pipe running down from the thermostat hosing / back of the Engine to the Lower hose as normal And Sandy told me to use 50/50 antifreeze & deionised water ....not tap water & dont use that Waterless crap stuff The big Alloy Water Rad seems to help also Never had my car run so cool both water & oil & Combe was crazy hot at FCS Wil Declaudio couldn't believe how well my temps were running ....ove I'm happy ... |
Twangy
Senior User Location: heswall Registered: 27 Jun 2014 Posts: 623 Status: Offline |
Post #857
Day666 wrote: demondriverdan wrote: How are you going to do the Aerocatches? I've still got to do mine at some point although it doesn't have hinge mount points like yours which makes it a bit more tricky! I'm going to do mine the same as blandy & my green race car Ross is buying ...sadly not got a clue how you would fit a non hinged one Dan my ones single skin and made small mould of hinge fixing points of original tailgate ,so mounts as normal hatch , job done ________________________________________ wayne mcardle |
blandy
Post #858
lol changed to a picture that makes senseWhats the idea with the holes in the thermostat? So do you run a flexible hose then or im guessing its all routed differently? |
Post #859
blandy wrote: lol changed to a picture that makes sense Whats the idea with the holes in the thermostat? So do you run a flexible hose then or im guessing its all routed differently? Thermostat rear metal bypass blanked at thermostat housing end & rear bottom hose end .... Because I have no rear engine routed metal pipe you give the water a easier route allowing the water to flow through the easiest route it's always looking for ...keeping it flowing but restricting it somewhat Basically because it had NO Heater & no rear engine metal bypass hose as well ...its directing & forcing the water with the thermostat drilled around the head better Seems to work a treat as Figures prove ? |
blandy
Post #860
Definately- silly question but any pics of the routing etc of the pipes as im in a similar position running no heater but at min with a joiner to bypass which looks messy. Ive toyed with having the outlets on the stat housing brazed up just to tidy it all up |
Post #861
Big thank you to Cully :I love He was filming in his beautiful white 6 at Combe with his lovely Daughter when I passed him on the right & he swore & didn't think I was going to make Quarry ..:coming through folly / Avonrise on our way to Quarry the most dangerous but quickest part of the track .... I was doing about 139-141 at that point braking late ...& saw another gap infront of the black 106 was it ?..... He spun way after I passed just after the Essses You can hear Cullys daughter laughing ... Great footage Paul /Cully your a gent & extremely helpful good bloke to us forum users be it OC or 6 forum ....keep up the great work on your car also ...it's looking amazing https://m.youtube.com/watch?feature=youtu.be&v=O5vU1KqUocA |
Post #862
That's interesting about the 50/50 do-ionised water and anti-freeze. It's what I have done on both my cars for years but read somewhere on the Internet a few weeks back that this isn't really recommended as the water will try to get ions from somewhere which will almost always be the aluminium that it contacts, so will corrode the head faster than say normal tap water. I still do mine this 50/50 mix way regardless. ________________________________________ Goldie the track car. |
Post #863
prism7guy wrote: That's interesting about the 50/50 do-ionised water and anti-freeze. It's what I have done on both my cars for years but read somewhere on the Internet a few weeks back that this isn't really recommended as the water will try to get ions from somewhere which will almost always be the aluminium that it contacts, so will corrode the head faster than say normal tap water. I still do mine this 50/50 mix way regardless. Your spot on ....but That's why the 50% Anti corrosion Antifreeze is needed |
Post #864
Little update ...weighed my complete tailgate 3.8kgs ....so The Twinskin Fibreglass one with Aero catches fitted but not sprayed YET with the same but new (glass) is 1.1kgs saving 2.7kgs now that can't be sniffed at ...I'm not going for (blown molded hardshell Polycarbonate) just yet as its bloody expensive ...doesn't give stiffness to the tailgate like glass does & can lightly scratch ...Yes much much lighter but 2.7kgs saving I'm more than happy with & I get glass Free All fitted & tested & ready for my m8 to spray it as a favour owed Day666 has attached the following image: |
Post #865
Stronger Steel pins not Red alloy ones used ....ones for 4x4 Aero Catch who supplied steel pins ...Took 1hr to fit complete system ....PLEASE make sure you don't buy them off Ebay as lots of Fakes about Day666 has attached the following image: |
Post #866
Hole made in bottom of tailgate each side with Dremel for pin to go through easy Day666 has attached the following image: |
Post #867
This is what it looks like closed position & locked shut from the inside Tailgates 99% spot on fit ....I'm well pleased Day666 has attached the following image: |
demondriverdan
Post #868
That looks like what I'll do if / when I ever get round to fitting mine. I'm going to bond some hinges to the top to make it easier. Having to remove the whole hatch will be a pain in the arse!________________________________________ Rallye Race Car |
Post #869
Nice work, I've got a single skin fibreglass one to go on mine but I might get a twin skin like yours as I want to use hinges and have some form of rigidity as I'll be fitting polycarbonate to mine. ________________________________________ Goldie the track car. |
demondriverdan
Post #870
I'm hoping the polycarbonate will help strengthen mine enough that it doesn't flap around too much________________________________________ Rallye Race Car |
Post #871
demondriverdan wrote: I'm hoping the polycarbonate will help strengthen mine enough that it doesn't flap around too much Blown moulded Hard shell 4mm Polycarbonate does help (a little) but not much ....I'm getting 5mm one off made in slate Grey tint it's 40% stiffer & close to glass ..but it's telephone nos & I'm just fitting a new 4mm glass rear window this year |
rallyeash
Post #872
Well done mate, what were you lapping Combe in? ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
Post #873
rallyeash wrote: Well done mate, what were you lapping Combe in? Hello Stranger ....saw your great result on Triathlon ...FairPlay Thank you Ash ....it's been a messy journey but got here at last .. Only timed it rough on my phone GPS / video in the morning when only 4-5 cars on track & was in mid - 1.16s but getting familiar to the completely new car .... But Will Declaudio said I was much quicker in the afternoon & one lap ...I felt I was on it ....The Car had more to give but I didn't & I was Beaton up ....with no PAS fitted now .. I would love to wish /think low 1.16s but I am running DZ03Gs not Saloon championship legal ...which helps s & allows me to carry much more speed through the corners than ADO8s |
rallyeash
Post #874
Quick!! Are you going to race it then? Hopefully we can get out on track together somewhen!________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
Post #875
rallyeash wrote: Quick!! Are you going to race it then? Hopefully we can get out on track together somewhen! Not got the time or money and most importantly my Girlfriend would leave me .... Just going to do as many track days this year as I can afford but want to do Croft & Oulton next year |
