displaying posts 926 to 950 of 3424
Pages (137): first .. 37 [38] 39 .. last
marksorrento205
Post #926
I have done a couple of 205 ones. Piece of p**s and work well. Corsa B is the better column to use imo.
Posted 20th Jul 2016 at 19:50
blandy
Post #927
Is there difference between corsa c and b? I have a c column.
the thing that attracts me to it is that it's adjustable so can turn it off if wanted
Posted 20th Jul 2016 at 20:38
Post #928
Get the knob ajuster off RallyWiz / Ireland not the Ebay Portugal bloke as they don't last & are open to the elements Thumbs up
I've been told 205 ones are loads easier to do than 306 ones Thumbs up
I'll find out soon
Posted 20th Jul 2016 at 20:55
marksorrento205
Post #929
The b column just fitted the 205 a treat. I'm. Sure a c will fit with some fettling
Posted 20th Jul 2016 at 21:03
Post #930
Ok a little update ....I've received my Vauxhall second hand Corsa B electric powersteering & Power ajustment knob / small box ...
The kits below & all looks straight forward enough apart from the obvious ignition barrel etc ..
I'm going to have to buy a Momo Vauxhall Steering boss now to fit it Crazy
The ECU box is on the bottom left of the picture/ metal & black plastic ....it's easy enough to find a place out of site for it Thumbs up
Uses 50amp fuse supplied
Posted 2nd Aug 2016 at 12:36
Post #931
I've already worked out how the original Column Stalks will fit ..easy enough & they can be moved closer to the steering wheel with this method ...I have a wheel spacer see & the indicators are 30mm to far away for my liking ....
I have had a simple idea to make a simple triangle spacer adaptor plate to bolt onto my original column support bracket because the angle of the Corsa B PAS if different to 306 standard one ..
Pics to follow soon with prototype ....this way it just bolts on without having to remove the dash or Column support & can be removed for easy access ..
Spare Column support bracket below used for making Spacer adaptor ...ill make a template out of cardboard first ...then Metal with x4 welded bolts after I'm happy the angle & idea is good ....
Posted 2nd Aug 2016 at 12:47
Post #932
Picture below of Adjustable PAS Electric power steering knob ....
Will fit Nicely on the Fibreglass dash ..don't buy Ebay ones ..they burn out !
The good thing is I will be able to design & fix my steering wheel angle to what I want ......it needs to come down 40mm as it is now & angle down a little
Posted 2nd Aug 2016 at 12:50
Twangy
Post #933
keep us posted to show how you get on damien , and what you think off steering m8
wayne mcardle
Posted 2nd Aug 2016 at 12:58
demondriverdan
Post #934
Looks good, keep us up to date. I will probably be doing the same shortly
Rallye Race Car
Posted 2nd Aug 2016 at 13:48
Post #935
I've been told even on the lightest assist setting its still far to light ?
If that's the case I will just turn it off if I'm not on the road or driving it up Prescott where I needed it so bad ....fingers crossed ...
I'm hoping as I have a phase 1 2.4 turn rack fitted it may be better ?
This won't be fitted or really happening for 2-3 weeks as I've loads to do other than the car & I will start making the Bracket end of the week ..
I will post as soon as I have product ....
Not as quick as I normally do ...but sadly other things on at the mo Thumbs down
Posted 2nd Aug 2016 at 15:30
Post #936
Beware !
yours is a racing car Dan ....I've spoken to RallyWiz & they warned me it maybe too assisted & light even on the least assisted setting ?
Ideally I wanted half the assist of the Hydralic pump standard one Whistle
It will stay on
Mine as I really need it for the MOT /Road & Prescott ....a little steering assist at Combe wouldn't go a miss either LOL
My MOT tester couldn't turn the wheel of drive it unless it was moving ...Sandy struggled getting it onto the Rolling road ...just a pain without PAS ...
You feel the track better but at a cost of feeling like you've done a few rounds of Boxing ....
Posted 2nd Aug 2016 at 15:42
cully
Post #937
psss how have they wired the pot into the ecu loom?? Wink
Posted 2nd Aug 2016 at 15:41
demondriverdan
Post #938
Yea, it's a risk it'll be too light. Whatever I do I'll make sure it's reversible so I can put a standard column back in if I want to.
I only want a bit of assistance, I get knackered in the car after a stint sometimes and would like a little bit of help.
Rallye Race Car
Posted 2nd Aug 2016 at 15:43
Post #939
You have the other trouble too with a race car - if you're on sticky enough slicks you can overpower them and the unit will switch off. Good for puckering seats mid corner. Mind I think you'd struggle to mount something wide and sticky enough on a 306.
Posted 2nd Aug 2016 at 15:45
Post #940
They have two wires into ajustable switch ....orange small ignition on /off switch feed & (+) permanent into ajustable switch then from the ajustable switch three wires ( brown / White / Green ) with white plug in picture to ECU ...
The Blue plugs just 50amp feed (+ & - ) into ECU
Into ECU the Green plug & black small plug in picture is from PAS steering itself
Posted 2nd Aug 2016 at 16:13
Post #941
Easy enough to make for you Cully Thumbs up
Posted 2nd Aug 2016 at 16:15
cully
Post #942
im guessing there is some extra electronics in the box with the switch pot, as it needs to produce a varying frequency pulse to feed to the PAS ecu, this is for speed ref to enable the varying assistance
Posted 2nd Aug 2016 at 16:47
Post #943
I'm not 100% sure ?
All I was told was all the switch does is the same as you said with speed ....the faster you go the less assistance it would normally give on original car & the switch overrides this & keeps it from changing if it was in the original car ...
Freq Pulse sounds familiar Thumbs up
It changes it with MAGIC LOL
Posted 2nd Aug 2016 at 16:58
demondriverdan
Post #944
Will be interesting to see what you think. I think it's worth a shot, if it's crap then I'll take it off and sell it Big grin
Rallye Race Car
Posted 2nd Aug 2016 at 17:08
cully
Post #945
the corsa has several assistance maps in the ecu dependant on V/speed
im guessing the switch just picks one of them via frequency pulse or off
just found a very good page on how to make it progessive without the switches Wink
http://www.super7thheaven.co.uk/blog/corsa-c-electric-power-steering-epas/
Posted 2nd Aug 2016 at 17:18
Post #946
It won't fit the standard 306 fixing column in the picture below & the steering knuckles / connecting rod to steering rack won't fit ....so a fair bit of fabricating & welding needed....I wouldn't mess around with cutting & shutting to much Dan Thumbs up
I'm just making adaptor plates so I can fit that & remove in 30mins & fit old if needed Whistle
Post #947
Great read & I have one of those nasty boxes LOL
Posted 2nd Aug 2016 at 17:28
devere
Post #948
My 106 hydraulic pump is still providing resistance and feedback. Bit I run a lot of castor on the front. I would assume you will gain more feedback and resistance of you had added castor also on the corsa column.
Posted 2nd Aug 2016 at 17:35
Post #949
Once it's fitted Im willing to try that & other stuff if it's to light ..great Idea Thumbs up ...top man Martin
Posted 2nd Aug 2016 at 18:10
demondriverdan
Post #950
I'm sure I read somewhere that the knuckle works with a 306 one? Maybe it was a 205
Rallye Race Car
Posted 2nd Aug 2016 at 18:55
