displaying posts 1101 to 1125 of 3424
Pages (137): first .. 44 [45] 46 .. last
Post #1101
A Few Access holes for hinges & door lock areas drilled out ...look at pics below I can now be sure that the doors are 100% Kevlar Thumbs up ....
Also on the hinge areas inside thick Alloy 8mm plates have been sandwiched to reinforce the areas ..I found this out while drilling today to trial fit Passenger door I'm well pleased Thumbs up
Update & hopefully good news & pictures tomorrow of door trial fitted to a spare car
Posted 13th Mar 2017 at 20:35
Post #1102
Hinges fitted ..had to move up hinges 5mm
I'll get the important Drivers side one 100% ...got a standard template off original door & they are slightly different by 5mm....no harm done ...I'll fill two holes drilled wrong ....
Posted 14th Mar 2017 at 12:01
Post #1103
All cut out both sides for locks & hinges
Carbon fibre hides everything cutout
Posted 14th Mar 2017 at 14:16
RallyeRed
Post #1104
That's a carbon kevlar mix you have there Dan.
Nice material; supposedly has the strength from carbon and the impact resistance/flexibility of kevlar all rolled into one.
Looks like they did a good job of those doors.
Posted 14th Mar 2017 at 14:38
Post #1105
Thank you Iain ...I'm not qualified in Kevlar or Carbon to say .....Twangy!!!!!
Fitted the passenger door to my m8s old scrap 3door ...fitted not far off original & im very impressed....it's 95% spot on without even moving the body hinges.....
Posted 14th Mar 2017 at 15:05
Post #1106
Yeah, that's a carbon/kevlar mixed cloth, used to do the bodywork in the same stuff to give it a bit more impact and abrasion resistance:
Posted 14th Mar 2017 at 15:15
Post #1107
So it's good stuff then Phil Thumbs up
I just want then stronger & stiffer than Fibreglass ...just in case ...hopefully I won't need to test them ...
Hope that Buggys getting some TLC still ?
Posted 14th Mar 2017 at 16:09
Post #1108
Aye, well, not that one, that one sold a long time back, but ours is getting there, waiting on a digidash arriving atm and some brake pads and that's it, painting time. Probably should update the thread LOL
Posted 14th Mar 2017 at 16:35
clen666
Post #1109
I'm impressed Thumbs up
Team 'unintentional rat look'
Posted 14th Mar 2017 at 17:04
Post #1110
You should ....What dash make you getting ?...seen some beauties at Combe ....full colour & Data logged easier than my DTA...Thumbs up
Posted 14th Mar 2017 at 17:44
Post #1111
Thank you Smile
I really would say if they weren't brilliant & they are as stiff & flex less even at the top that gets bent out by thiefs less than my Metal ones with nothing cut out ...only small issue is getting the Hinges height 95% correct ...the distance between is easy but because no marking for them to go anywhere unlike the lock side ...and you don't have much movement to ajust them up & down ...only side to side !
I did make & take a template off original doors ...but as I've said in the earlier post I was out on both hinges by 5mm ...
The square Alloy block you can't see until you drill the holes that's sandwiched between the Kevlar is so thick & ive had to use x4 -45mm bolts to go through hinges & door thickness which I'm so pleased about ...
Now I've got the passenger side spot on I'm making a template for these doors only to reverse & sort drivers side out ..
I've contacted Tony Palfrey of Maxi Motorsport who supplied them & he's really pleased how they fit ....he's never supplied a pair of these in Kevlar before & it's always great to know what your selling Quality wish Thumbs up
The lock picture below is was all marked out by the manurfactures so easy Dremel cutout job
I'm really hoping to get them sprayed & as with my fibreglass bonnet & tailgate not be able to see they aren't Metal ....which shows how good they are made & sprayed Whistle
Posted 14th Mar 2017 at 18:05
Post #1112
Holes drilled ready for door latch & handle fitting ...no key lock or lock push button will be used & as I've said no holes will show once Carbon door panels fitted ...
I'm using the original inside door opening handle system as it's easy to fit & works well & is lightweight enough......I can use
Twangy Previous door cards as a template seeing as I've cut the handles out already
Posted 14th Mar 2017 at 18:11
Post #1113
The new DTA one that's just come out, with full logging and GPS + g-sensors.
Posted 14th Mar 2017 at 18:17
Post #1114
Pics please Thumbs up
I was speaking to him about it 6months ago ...
Posted 14th Mar 2017 at 19:04
Post #1115
Yeah, I had a word about it, then we wet to have a look at autosport and bought one, still not here though, he's had some delays.
Posted 14th Mar 2017 at 19:29
Post #1116
I would love one but I've got a good idea how much they are & I'm
Going to need both my doors sprayed & Polycarbonate AR windows bought ....
Phil will they work easy with all the sensors not coming through the DTA ?
I know some do easy & others on the market don't ?
Posted 15th Mar 2017 at 09:32
Post #1117
Door latch & door handle install ...
I'm not cutting the area marked in black marker because I've got enough room now to install everything Thumbs up
Posted 15th Mar 2017 at 20:19
Post #1118
I do like that inner door skin design!
I wouldnt have bothered with doorcards!
Posted 15th Mar 2017 at 21:09
Post #1119
Thank you ..
I want to run opening standard handle on the door cards & Wil Declaudios door panels from the same company on his 106 have stiffened the doors up 15-20% more & I wanted the holes etc hidden Whistle
Posted 15th Mar 2017 at 22:08
Twangy
Post #1120
nice update damian , nice to see more progress on car mate
wayne mcardle
Posted 15th Mar 2017 at 22:29
Post #1121
Big thank you Wayne Thumbs up
My Friend had a pair of handles for me off a smashed up 306 getting scrapped but forgot to tell me he removed them in a different kind of way LOL
He said the actual door surround / metal would come in handy to see size & shape I need to make mine ....he's got a point but I'm not fitting barrel locks though just the handles Thumbs up
Posted 16th Mar 2017 at 14:04
Post #1122
He also gave me a pair of door Latches ...I may need to look for a pair of base model none central locking later on as I'm not using any of that extra side
Posted 16th Mar 2017 at 14:07
Post #1123
Lightweight door latches
Posted 16th Mar 2017 at 14:32
Post #1124
Door handle rectangular hole cut out & latch fitted & works like original Thumbs up
Posted 17th Mar 2017 at 19:16
Post #1125
Thanks Phil but I'm using OE ones as they fit without to much modification m8 Thumbs up
Posted 17th Mar 2017 at 19:31
