Stickers from Halfords.
Neons.
McDonalds tea trays under the rear wheels.
A driver.
| Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #1226
phillipm wrote: Mahoosive diffuser. Stickers from Halfords. Neons. McDonalds tea trays under the rear wheels. A driver. |
Post #1227
cully wrote: A diet for the driver ![]() Already cut out Bread & junk food 15.5 stone now & 15s my goal ... |
Post #1228
Bit of a expensively big Friday update Just got my rear damper pics they are one offs = 40mm pistons with 3way remotes ..... John from Black Art Design just sent me nearly finished Pics.....bumpstops & a few more bits to go inc rod gator protectors All ready for Ross/ Superchargers 25mm Torsion Bars ....big thank you Ross PS big thank you to Denis / Russian guy for all his help too .....Denis are 36mm pistons & these have modified 40mm ones with more oil to keep them cool on bumpy tracks Day666 has attached the following image: |
Post #1229
Should be a little more sensitive to small movements too, which helps on the rear of a 306 given the leverage ratio - I ran 44.5mm pistons in the rear Foxes for the same reason.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
fatlapit
Post #1230
Ull defo need them at coombe place is like a plowed field________________________________________ |
Post #1231
phillipm wrote: Should be a little more sensitive to small movements too, which helps on the rear of a 306 given the leverage ratio - I ran 44.5mm pistons in the rear Foxes for the same reason. Did you need to modify the subframe To fit 44mm Pistons in Philip ? I can only just get 40mm piston = 52mm outer in standard subframe ...I want it twitchy at the back Phil & I believe 25mm TBs & these 3ways should control them easy ... Also John ajusted the rebound for my rear spoiler seeing as it puts 180kgs of weight down on the rear at 120 mph |
Post #1232
fatlapit wrote: Ull defo need them at coombe place is like a plowed field Thank you Chris.... Yes ....I'm a little concerned about 25mm TBs.... seeing as it's so bumpy but also have 23mm TBs just incase & Johns made the 3ways to be able to ajust |
Post #1233
Day666 wrote: phillipm wrote: Should be a little more sensitive to small movements too, which helps on the rear of a 306 given the leverage ratio - I ran 44.5mm pistons in the rear Foxes for the same reason. Did you need to modify the subframe To fit 44.5mm Pistons in Philip ? I can only just get 40mm piston = 52mm outer in standard subframe ...I want it twitchy at the back Phil & I believe 25mm TBs & these 3ways should control them easy ... Also John ajusted the rebound for my rear spoiler seeing as it puts 180kgs of weight down on the rear at 120 mph |
Post #1234
That's a lot for that small a rear wing, you'd have to be running a fair amount of AoA/drag? The tri-plane for the buggy only makes about 775 at 120 and it's pretty damned draggy at that (not that it matters much given it's pretty much a brick with 4 parachutes on each corner ) The Foxes were smoothbody with a CDS steel outer so the wall thickness was a lot smaller compared to threaded ally bodies (not as fancy as yours! ), they only come out at 50.8mm O/D, and the caps are internally retained, so the same size as the body________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Post #1235
phillipm wrote: That's a lot for that small a rear wing, you'd have to be running a fair amount of AoA/drag? The tri-plane for the buggy only makes about 775 at 120 and it's pretty damned draggy at that (not that it matters much given it's pretty much a brick with 4 parachutes on each corner ) The Foxes were smoothbody with a CDS steel outer so the wall thickness was a lot smaller compared to threaded ally bodies (not as fancy as yours! ), they only come out at 50.8mm O/D, and the caps are internally retained, so the same size as the bodyPhil I put it a little lower about 10mm below the roofline you are limited where you can fit a F2000 rear spoiler ....& the Angle of Attack is fixed sadly.... ...thinking I don't want to much drag ...Demondan said it was really draggy but great in the Wet ....on Dans pics it appers he has his a little higher where it should be ...mines Lower than the swept down roof line PS ....I'm hoping with the extra power I'm running over Dan it will make les's difference maybe ...we shall see ??? Are those rear fox dampers off a 306 touring car ? |
Post #1236
No, they were some I made ages back as prototypes to refine/get some feedback on the valving, they're floating around with someone on here somewhere ![]() Low down's not that bad if you can couple it with a lower lip - run a spoiler around the rear of the tailgate - it'll couple and help pull air from under the car at the rear then, if you fit a diffuser it'd drive it even harder, and it doesn't really cost you anything drag-wise on a hatch if you already have an aggressive upper wing anyway. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Post #1237
306 touring cars had Penske, at least the ones I've seen were, I think they were built by a few different teams so not all the same.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #1238
Yeah, someone fetched me some to dyno/check over once, they had seperate air-over-hydraulic bumpstops in a remote canister with a screw in adjuster for pressure/ride height control, very trick.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Post #1239
Great info Phil Well guys I've just been told I've got a delivery waiting for me Any guess what it could be ? Clues on earlier post I've not seen the finished product yet ...so I'm a little bit excited being a sad person Day666 has attached the following image: |
Post #1240
I know this one, it's a box.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Post #1241
phillipm wrote: I know this one, it's a box. YES ....But a dam expensive one |
Post #1242
phillipm wrote: No, they were some I made ages back as prototypes to refine/get some feedback on the valving, they're floating around with someone on here somewhere ![]() Low down's not that bad if you can couple it with a lower lip - run a spoiler around the rear of the tailgate - it'll couple and help pull air from under the car at the rear then, if you fit a diffuser it'd drive it even harder, and it doesn't really cost you anything drag-wise on a hatch if you already have an aggressive upper wing anyway. Phil ...looked at the Fox rear damper project 2009 -on .....why did it never happen ? ....people seemed to be lined up etc ? |
Post #1243
I know everybody says this.....The picture really doesn't do these pair justice ![]() (BIG) Thankyou to Russain guy / Denis Day666 has attached the following image: |
Cjwatson27
Post #1244
Is that a heavy duty cock pump ? If so where did you get it from ? ________________________________________ Old pugs don't die they just get faster |
Post #1245
Cjwatson27 wrote: Is that a heavy duty cock pump ? If so where did you get it from ? If it was I'd be in films |
Post #1246
Also something that may interest a few others on here ?Marine clear spray for anti rust of all metal parts ...not cheap but got this free off B.A.D Day666 has attached the following image: |
Post #1247
It's the stuff Meister sells, BAD do their pistons/internals (Fitted a set to the Eunos a little while ago)Foxes was mainly I wanted those ones run on a few setups to fine tune the valving and by the time they got fitted the drop in exchange rate buggered them up a bit. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
RallyeRed
Regular Location: Northwich Registered: 03 May 2016 Posts: 353 Status: Offline |
Post #1248
Yep I've got the same stuff from Meister R for my Impreza coilovers. Used it, but I doubt they'll get too rusty in the box they arrived in - where they still reside.... |
Post #1249
phillipm wrote: It's the stuff Meister sells, BAD do their pistons/internals (Fitted a set to the Eunos a little while ago) Foxes was mainly I wanted those ones run on a few setups to fine tune the valving and by the time they got fitted the drop in exchange rate buggered them up a bit. Shame that Phil .....they did look amazng Yes John from B.A.D did mention he modifys the internals of Meisters ...that would make sense I'll try it |
clen666
Post #1250
Day666 wrote: phillipm wrote: It's the stuff Meister sells, BAD do their pistons/internals (Fitted a set to the Eunos a little while ago) Foxes was mainly I wanted those ones run on a few setups to fine tune the valving and by the time they got fitted the drop in exchange rate buggered them up a bit. Shame that Phil .....they did look amazng Yes John from B.A.D did mention he modifys the internals of Meisters ...that would make sense I'll try it That's interesting, I read a thread on a jap car forum, maybe Impreza or civic, where a Meister rep was trying to drum up some interest but I think he ended up getting a load of grief. I seem to remember them saying they had a reputable name on board to alter the internals but not much more info was given. To be honest I'd written them off as a cheap import but they may be decent? ________________________________________ Team 'unintentional rat look' |
