displaying posts 1526 to 1550 of 3424
Pages (137): first .. 61 [62] 63 .. last
Post #1526
After looking for a pair of these 44 x 52mm.....got a pair coming for my Rear damper Canisters ,..I’m putting them on each side of the cage (inside) the car at the rear Thumbs up
Posted 21st Oct 2017 at 18:29
Post #1527
Hopefully putting the canisters in the car will make it much easier to adjust Whistle
Hopefully get these fitted tomorrow night ? ....25mm ARBs fitted just Dampers plus Canisters
Posted 9th Oct 2017 at 00:03
Post #1528
cable ties are lighter Razz
Posted 9th Oct 2017 at 00:34
Post #1529
I'd imagine anything is lighter than that hunk 'o' ally!
Mine are either mounted with jubliees or the interlink canisters are just held with a plastic clamp.
Posted 9th Oct 2017 at 02:09
Post #1530
quote:
[quote="welshpug!"]cable ties are lighter Razz
100% NO LOL
Posted 9th Oct 2017 at 06:15
Post #1531
quote:
[quote="phillipm"]I'd imagine anything is lighter than that hunk 'o' ally!
The problem is guys ...the canisters have much larger top / bottom ends ...plus the weight is nothing Razz
Weight saving but practical apart from the PAS removal Whistle
Posted 9th Oct 2017 at 06:19
Chr1sch
Post #1532
Still looking amazing Damien, keep up the good work, those cage mounted canisters will look amazing!
Posted 9th Oct 2017 at 11:28
Post #1533
thank you Chris Thumbs up
I hope so Whistle
Posted 9th Oct 2017 at 13:09
Post #1534
My Penske canisters have much larger top and bottoms.....I undo the bolt, and out they come Razz
Posted 12th Oct 2017 at 22:16
Post #1535
quote:
[quote="phillipm"]My Penske canisters have much larger top and bottoms.....I undo the bolt, and out they come Razz
You’ve got to have some sensible bling in your life Razz
Hopefully won’t have to remove mine for a very long time Whistle
Posted 13th Oct 2017 at 07:16
Post #1536
Started on the rear today ...fitted /finished the rear beam with 25mm torsion bars.... plus changed yet again both arm as I got offered a pair of second hand Plus 40mm rear arms 1.5 degree Camber at sensible money ...which I really wasn't planning on going this way.... but hey ho ....plus 50mm front / plus 40mm rear now ...they look similar to Bridgecraft ones ?
Fitted the 40mm not 38mm rear Black Art Design / Dampers with Oring seals both sides plus both ends to stop dirt / water Etc getting into spherical bearings ...sort of getting somewhere now Whistle ...
Posted 25th Oct 2017 at 06:16
Post #1537
Really happy with the fit ....remember these are larger Cylinders than my Group A Old Bilsteins or larger than standard Black Art Dampers 40mm pistons instead of 38mm...
John from Black Art wanted to try a upgrade from 38mm to 40mm with 3way with Canisters / said he could machine the tops of the Dampers out for them to work ....he was spot on Thumbs up
Posted 25th Oct 2017 at 06:18
Post #1538
Cut a small hole in the floor to get the Canister inside the car Whistle
Posted 21st Oct 2017 at 16:18
Post #1539
Use two inserts to fix alloy plate back down
Posted 21st Oct 2017 at 16:19
Post #1540
I think you all get what I’m doing now ....
PS all the swirl pot / plus Fuel lines will be changed for next year as I’m taking out the standard tank plus fitting a sunk in ATL type tank with built in Pump plus swirl behind the Passenger seat then it will have a lid ....much safer plus legal LOL
Posted 21st Oct 2017 at 16:23
Post #1541
Should have my Billet clamps for canisters Monday but black insulation tape will do to get a idea of where it’s going for easy access
Posted 21st Oct 2017 at 16:26
Post #1542
Also got time to underseal beneath my arches before fixing the F2000 plus 50mm Wings ....I’m surprised NO rush ?....
Posted 25th Oct 2017 at 06:19
Post #1543
Small update ...
Received my lower arm extensions plus Steering arm Extensions
Posted 25th Oct 2017 at 16:29
Post #1544
Then steering arm tubing is about 4mm thick tubing Whistle
Posted 25th Oct 2017 at 16:31
Post #1545
The internal thread is 40mm long as well / stops by my hand in the picture Thumbs up
Plenty strength LOL
Posted 25th Oct 2017 at 16:34
Post #1546
Plenty of Ajuster ...still some inside
Posted 25th Oct 2017 at 16:40
demondriverdan
Post #1547
Just cable tie the canisters on! Razz
Rallye Race Car
Posted 26th Oct 2017 at 08:45
Post #1548
quote:
[quote="demondriverdan"]Just cable tie the canisters on! Razz
As much as I’d love to Dan ...I’m not You.... Animal LOL
I could of bought some rubber wedge separators plus cable tied or even used a large jubilee clip ....but I thought sod it Crazy
Hope your Engine / Rear axle makes a massive difference m8 Thumbs up
Posted 26th Oct 2017 at 11:02
Post #1549
Big rubber lined P-clip. Think of the weight saving.
Posted 26th Oct 2017 at 15:37
Post #1550
quote:
[quote="phillipm"]Big rubber lined P-clip. Think of the weight saving.
Decided not eat for two weeks before I drive the car Razz
Posted 26th Oct 2017 at 16:07
