PS ....thank God no rust at all below old fuel tank ...bonus
The exsisting Stainless middle section of the Exhaust will be modified to now come straight out the middle of the rear of the car ...no bends
| Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #1626
Where the tank was now gives me a whole load of room to sink the ATL alloy Box into the floor behind passenger seat below rear bench seat and maybe relocate my battery which is sunk into the boot floor to behind drivers seat opposite side of ATL ....hopefully no full sloshing around will help too ....PS ....thank God no rust at all below old fuel tank ...bonus The exsisting Stainless middle section of the Exhaust will be modified to now come straight out the middle of the rear of the car ...no bends Day666 has attached the following image: |
RallyeRed
Regular Location: Northwich Registered: 03 May 2016 Posts: 353 Status: Offline |
Post #1627
Looks good Damien. Will be interesting to see how your new fuel cell fits. Are you making a hole for it to sink into, or are you fabricating a box in your floor pan? |
Post #1628
quote: [quote="RallyeRed"]Looks good Damien. Will be interesting to see how your new fuel cell fits. Are you making a hole for it to sink into, or are you fabricating a box in your floor pan? I’m using the Alloy rectangular box that the plastic fuel cell sits in I’m cutting a rectangular hole the size of the alloy box and sinking it into the floor level with the outside underneath the car floor pan ...so the weight when full of fuel in low similar to standard tank .... that means it will sit 1inch higher than the top of the metal curved bench seat (inside) the car ...I’m welding alloy 30mm angle all around 4 corners onto the top edges of the ATI alloy box which will stop it falling through the floor rectangle hole ...then using 4mm flat rubber between under the 30mm alloy angle between the steel floor to absorb some vibrations and some sound and bolting it down ... That’s the plan at mo ....all may change yet |
Post #1629
Small update ....Bought a Pro Stack oil Temp gauge kit to go in my dash to give me a much better visual and it changes col when below or above with a audible buzzer etc Had to buy a M14 x 1.25 Brass adapter to fit the sensor to the front middle of the sump where the old standard sensor was ... Only got to buy another for the Water Temp and then all the dash info I will get is MPH and REVS / fuel ....but I have a large Stack Rev counter separate and in 4/5 Weeks my ATL fuel cell will arrive with separate fuel gauge also ..... so I can see the dash coming out at some time this year ( GPS speedo ) ?Day666 has attached the following image: |
Post #1630
Fitted new 25mm Samco flouro lined for oil breather pipe that comes from top of rocker into box and then oil goes back into the block of the engine ...Picture below and next posts shows it ..nothing special....had clear nylon webbed plastic water pipe before that went hard and was cracking ...very little oil really appears to travel through it ? Day666 has attached the following image: |
Post #1631
Oil Catch tank from rocker cover to bottom of engine block ....much happier with it now Day666 has attached the following image: |
Post #1632
A very Small update ...but one that will enable me to trial fit my front plus 50 bumper ...the oil cooler was upside down / wrong way and oil cooler pipes were to low which now the cars lower than before is-no good now ...Few mods completed to the rad and Alloy brackets bent and welded to enable the oil cooler to sit 1inch in front of the radiator enabling the plus 50 front new bumper to sit further back ... The Oil cooler is in better direct air flow now also Not in the picture gone from 13 inch fan to 11 inch now which is still over kill Day666 has attached the following image: |
Post #1633
Welded bracket made to support drivers side with rubber mounts top and bottom ...just passenger side top to sort now Day666 has attached the following image: |
Post #1634
I’ve made this simple so I can remove the oil cooler easy when changing draining the engine oil ...just two bolts each side Day666 has attached the following image: |
Post #1635
I’m happy with it just a few more holes to drill to fix Day666 has attached the following image: |
superchargedblack1997gti6
Post #1636
Don’t forget to make the bumper quick release mate looks good________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
Post #1637
quote: [quote="superchargedblack1997gti6"]Don’t forget to make the bumper quick release mate looks good Yes 100% doing that Ross ....got a few ideas already and going to see if I get anymore at the Autosport show Thursday m8 ... How’s yours going Ross ? |
Post #1638
Got to wait for Mr Satchell then we are go for. Have bought a plasma cutter for some more adjustments E ________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
Post #1639
I saw someone the other day had used aerocatches to secure their bumper, something i'm considering in the future. Eventually my whole car will be held together with the bloody things ![]() ________________________________________ Goldie the track car. |
Post #1640
That’s what were using on my rear and front ________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
Post #1641
quote: [quote="prism7guy"]I saw someone the other day had used aerocatches to secure their bumper, something i'm considering in the future. Eventually my whole car will be held together with the bloody things ![]() Bloody amazing things Stephen and I’ve looked at them and another button type push pin type system Open to any ideas though |
Post #1642
quote: [quote="superchargedblack1997gti6"]That’s what were using on my rear and front Ross how you finding them for holding on the bumpers ? |
Post #1643
Easy mate on the front were just looking at what to use on the side ________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
Post #1644
quote: [quote="superchargedblack1997gti6"]Easy mate on the front were just looking at what to use on the side Ross Doesn’t Aerocatch do ones to connect two panels together ? Another small update ..both Oil-cooler top mounts with rubbers fitted and new 11inch fan instead of the 13inch one fitted ...I’m happier now Day666 has attached the following image: |
Post #1645
Bumper trial fitted yet again NOW oil cooler and fan moved Day666 has attached the following image: |
Post #1646
Getting it done ...arches getting trial fitted next Day666 has attached the following image: |
Cjwatson27
Post #1647
Looking good mate ________________________________________ Old pugs don't die they just get faster |
99rallye
Regular Location: Hitchin Registered: 26 Aug 2009 Posts: 348 Status: Offline |
Post #1648
Looking good. How did you get your bonnet lifters to work with a fiberglass bonnet? Are they the standard struts? |
Post #1649
quote: [quote="Cjwatson27"]Looking good mate Thank you Chris ....how’s yours getting on my friend ? |
Post #1650
quote: [quote="99rallye"]Looking good. How did you get your bonnet lifters to work with a fiberglass bonnet? Are they the standard struts? Big Thankyou Nick The bonnets came from a 306oc group buy and mine being double skin came with the ball socket fitting in the same place as the original metal bonnet ...big bonus ... I had to rebond the front two skins together at the front corners / front middle ...filling the holes with slow expansion spray foam ...as in my earlier posts on track at 115-130 the wind gets between the skins into the hollow frame and the bonnet flex’s and lifts even with Aero catch’s ....well it did not any more I believe (Cully) or someone may remember or know the name of who they were ordered off of ? (PS only fibreglass) !!!!... I bought mine off another member who had ordered one on the 306oc group buy but didnt end up using it .... |
