displaying posts 1701 to 1725 of 3424
Pages (137): first .. 68 [69] 70 .. last
Post #1701
quote:
[quote="blandy"]hmmmm what did the old one noise test at?
89db everytime at Combe with my SB engine Thumbs up
Induction noise above 200dbs LOL
The first long round box helps out loads Thumbs up
Posted 23rd Jan 2018 at 18:10
superchargedblack1997gti6
Post #1702
Looks tidy mate. May well give a little increase in power without the bends.
Posted 23rd Jan 2018 at 18:43
blandy
Post #1703
nice and quiet take it they’ve used same boxes and just adapted the Center section?
Custom made on the car I assume?
Posted 23rd Jan 2018 at 21:22
Post #1704
quote:
[quote="superchargedblack1997gti6"]Looks tidy mate. May well give a little increase in power without the bends.
I can only hope Ross LOL
Just one little bend before the rear box so the rear box isn’t to low Thumbs up
Posted 23rd Jan 2018 at 21:59
Post #1705
quote:
[quote="blandy"]nice and quiet take it they’ve used same boxes and just adapted the Center section?
The front box they originally made took it with the rear box down from 96db to 90db then he made me a longer front box and down to 86db ...it’s been that ever since until my flames eventually burn out the front box wadding lol
He adapted this straight pipe to my measurements....NO CAR .....it should be close ....Hopefully LOL
Posted 23rd Jan 2018 at 22:06
blandy
Post #1706
All 2.5” bore?
Posted 23rd Jan 2018 at 23:06
Post #1707
quote:
[quote="blandy"]All 2.5” bore?
100% yes m8
Posted 24th Jan 2018 at 04:44
Post #1708
We are taking mine through the boot floor an out the centre of the tailgate, bit max power but frees up space for the flat fooor and diffuser. Have you run it with the exhaust back on?
Posted 24th Jan 2018 at 10:18
Post #1709
I wouldnt take it that max powery, a flat boot floor wont have much effect with it being that high off the ground!!
leave the box where it is and put the flat floor under it.
Posted 24th Jan 2018 at 10:47
RallyeRed
Post #1710
Was going to say the same - a flat floor needs to be pretty close to the ground to have a benefit!
Posted 24th Jan 2018 at 15:19
Cjwatson27
Post #1711
Or get some cobra side pipes
Posted 24th Jan 2018 at 17:28
Post #1712
quote:
[quote="superchargedblack1997gti6"]We are taking mine through the boot floor an out the centre of the tailgate, bit max power but frees up space for the flat fooor and diffuser. Have you run it with the exhaust back on?
Sounds interesting Ross ....I won’t be going that extreme Thumbs up
I didn’t even want a splitter and I hate the x4 support bars ...but because of the F2000 rear spoiler I’m going to need a little front downforce I believe?
Ross you will love my front bumper upper support bar all thin wall bent alloy and removable if you ever need too remove the rad or oil cooler .....bumper and Splitter come off easy too no bolts separate from bumper support Thumbs up
Posted 24th Jan 2018 at 17:59
Post #1713
Youres is Perfect mate mine is extreme but only on the track bumper the road going one is miles higher. The arches have been cut back so much can pretty much lower the car as low as I need. It’s all about being individual.
Posted 24th Jan 2018 at 18:03
Post #1714
Agree my friend....the old saying goes about everyone having a different opinion LOL
Posted 24th Jan 2018 at 19:46
Post #1715
quote:
[quote="Day666"]Agree my friend....the old saying goes about everyone having a different opinion LOL
PS ....hope it grows on me and it does it’s job ?
Post #1716
Well I’ve been welding on stepped bent plate onto the lip of my cross member to support the back underside of my splitter / bumper fixed together...
Below is the painted first coat of primer ..
X3 Aero lock fixing for inside base quick release Whistle
Posted 27th Jan 2018 at 18:07
Post #1717
Fixings going to be used on above picture plate = twist and lock nice and tight x3
Posted 27th Jan 2018 at 18:43
Post #1718
Right then ...been a little busy make a nudge bar to support and fix my bumper to ....as well as using it as a crumple zone incase of a accident..
It’s all made from 3mm Alloy Tube and then bolted onto the body ....
I’ve bent it using a hydraulic jack flat and set in a temp frame with x2 upright scaffold tubes to press against / welded up ...it bent easy ...all I’ve done is put 6 Marks spaced equally out the pressed on those 6 marks to get the curve sort of close ...
Then welded alloy retanglar 3mm plate to the top of the tube to fix the underside of the bumper too it will have the fixings above to the rectangular plate ...hopefully?....unless things change as I progress LOL
Posted 28th Jan 2018 at 13:09
Post #1719
Bolted on temp and checked for fit ....A sort of space frame bumper support LOL
PS very light
Posted 27th Jan 2018 at 18:19
Post #1720
Bumper support removed and retest bumper again ....check twice Drill once LOL
Posted 27th Jan 2018 at 18:20
Post #1721
With head lights removed you can see how it fits ..Thumbs up
Posted 27th Jan 2018 at 18:21
Post #1722
My m8s.... pulse Mig on 56 and 280 setting just about did the job ..I’m not that great at welding alloy ....it has to be bloody spotless and needs a lot of heat ....it’s not professional tidy job ....but good enough once sprayed and it wont be seen unless bumper comes off Whistle
PS everything cost me ZERO ...that makes a change ...that’s (((Twangy style))) LOL
Posted 27th Jan 2018 at 18:30
Post #1723
Behind the grill on top of the bumper x4 more Areo locs secures the top of the bumper to the Alloy 3mm Plate under the fibreglass bumper ...
All quick release NO Tools needed to remove it ... 2min job or that’s the plan LOL
PS the pic below doesn’t have the rings on that mine do ...these in the picture need a screw driver and I’ll be using thes for the wings to bumper ....together fixing only one per side Razz
Posted 27th Jan 2018 at 18:40
Post #1724
Small update ...
I Made these this afternoon (x2) pattern Moulds for composite or fibreglass ...
It’s a Radiator and Oilcooler cowling plus a angled lid from top of angled Radiator Cowling to ontop the rad over the top and hook over creating a rad heat soak lid below my ITG / Jenveys ...
It’s all reinforced with wood and alloy on the back to help keep straight and flat while laying composite material ...fingers crossed tomorrow Whistle
Posted 28th Jan 2018 at 19:00
Cjwatson27
Post #1725
This must becoming a full time job for you lol
Posted 28th Jan 2018 at 19:01
