Just got to fit Handbrake cables hanging in pic ....then new modified exhaust.
| Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #1776
Tank all bolted in & sealed around edges ....Just got to fit Handbrake cables hanging in pic ....then new modified exhaust. Day666 has attached the following image: |
Post #1777
This self adhesive-heat reflective stuff is stupid money but you can’t buy better and it will stop the stainless Exhaust warming up the ATL alloy Fuel box with tank inside that ...even though the 2.5inch pipe is 3inches Away Day666 has attached the following image: |
blandy
Post #1778
What size tank did you go for? |
Post #1779
quote: [quote="blandy"]What size tank did you go for? Bespoke 30litres Michael ....so simple to setup ...ok stupid money but future proof and bloody safe.... |
Cjwatson27
Post #1780
Looks a lot better than having the swirl pot on pump mounted inside the car ________________________________________ Old pugs don't die they just get faster |
blandy
Post #1781
quote: [quote="Day666"] quote: [quote="blandy"]What size tank did you go for? Bespoke 30litres Michael ....so simple to setup ...ok stupid money but future proof and bloody safe.... Definitely the way forward |
Post #1782
quote: [quote="Cjwatson27"]Looks a lot better than having the swirl pot on pump mounted inside the car 200% Chris ...much safer and quiet and I would never myself put or have a swirl pot and lift pump under my car ...hot Exhaust if it ever leaked ....my view ... I’m aware everyone does it though |
Post #1783
Nothing update really .....Had to run a fuel vent from the ATL ANC oneway upside down connection on top of the tank ...it lets the tank fumes out and stops the tank over expanding with pressure ....also if the car went over it stops the fuel escaping ... Goodridge 611 Teflon fuel hose that I use on fuel lines wasn’t needed so I used Aeroquip x3 Webbed ANC for vapour line ....I’ll buy Torques Teflon lined with ANC fittings if I smell any fuel ... I went Diectl into drivers side wheel arch where filler cap used to be ..... Day666 has attached the following image: |
Post #1784
This is inside wing inside filler cap .....so no smell should come back in ....hopefully ....Pipe is at top ....but pic isn’t great showing this Day666 has attached the following image: |
Post #1785
All hidden behind Original fuel cap Day666 has attached the following image: |
Post #1786
Saying goodbye to sunken stainless steel battery box 2kgs ... and 12kg Odyssey Pc925 battery (14kgs) Day666 has attached the following image: |
Post #1787
Current battery coming out is Amazing Battery but heavy and big .....(12 volts @ 28amp hr )..but 11.8kgs Day666 has attached the following image: |
Post #1788
New battery 2Kgs and 12volt @ 30amp hr and going behind the drivers seat and running quick charge connections to charge it from the boot Fair bit more of weight saving ... The tanks saved 7kgs total inc all bits added up ....19kgs on two items isn’t bad Day666 has attached the following image: |
Cjwatson27
Post #1789
That’s a lot of weight saving, how much electrics do you run in your car, my next project after getting the seats in is relocating the battery and I’m not sure on what to buy I was going to use a mx5 battery ________________________________________ Old pugs don't die they just get faster |
blandy
Post #1790
I’ve been using a cheap powervamp battery in mine iirc 20ah which has been fine |
Post #1791
quote: [quote="Cjwatson27"]That’s a lot of weight saving, how much electrics do you run in your car, my next project after getting the seats in is relocating the battery and I’m not sure on what to buy I was going to use a mx5 battery Straight forward job really Chris ...just ring me when your ready m8 |
Post #1792
quote: [quote="blandy"]I’ve been using a cheap powervamp battery in mine iirc 20ah which has been fine Problem Michael is turning over my engine m8 remember it’s a full race engine Will Declaudio has similar with his and had to fit a larger battery than he wanted to 30amp Lipo is good as you can get under £600 |
blandy
Post #1793
Lol Damien .. I’m a engineer by trade I do understand. Chris has a standard engine hence my advice |
fatlapit
Post #1794
Damien have u looked at our batteries from work________________________________________ |
Post #1795
quote: [quote="fatlapit"]Damien have u looked at our batteries from work What are they ? Has to be Lipo and not over £350 Chris ... I’ve had 2-3 Odyssey and Varley lead Acid and even with power isolated they self discharge sadly and are heavy |
Post #1796
quote: [quote="blandy"]Lol Damien .. I’m a engineer by trade I do understand. Chris has a standard engine hence my advice Lol....ok thought that was for me |
blandy
Post #1797
Na.. out of interest what compression ratio are you running on your engine? |
Post #1798
quote: [quote="blandy"]Na.. out of interest what compression ratio are you running on your engine? God knows it all Sandy top secret stuff ...don’t think it’s stupid but it’s fun to start with a normal small amount Odyssey/ Varley race battery when cold ... This Battery below is available in the UK ...bit more but reviews say nothing comes close ...power to weight Day666 has attached the following image: |
Post #1799
Seen Liteblox?Ahh 350 budget lol... I use a pc680, 8kg, been pretty good except under 2 degrees Celsius ________________________________________ Nothing to see here |
Post #1800
I also use the self adhesive heat reflect material, from somewhere else and a load cheaper. Will dig out the name________________________________________ Nothing to see here |
