displaying posts 2176 to 2200 of 3424
Pages (137): first .. 87 [88] 89 .. last
Post #2176
My metal 1x23 tooth clutch alignment tool for twin plate ...fits a treat LOL
Posted 29th Jan 2019 at 22:59
Post #2177
Tiny update ...
Bought a (Vacuum Servo engine blank) to remove the ugly unused engine side unit run by the camshaft ...don’t have a Servo any longer and Spooks did a simple cheap option and comes with O-Ring and two button hex head bolts and washers Thumbs up
Posted 6th Feb 2019 at 20:43
Post #2178
Made of Billet machined Alloy
Posted 6th Feb 2019 at 19:02
Post #2179
Pedal box thick 8mm alloy square spreader plate made and fixed can’t see that sadly at mo ....thin alloy top foot plate bent and folded a total pain as it has a step before pedals on top run ...
Alloy UNC screws used to hold plate in place
Pic below before griptape fitted
Posted 8th Feb 2019 at 14:56
Post #2180
Griptape went on well
Posted 8th Feb 2019 at 14:55
Post #2181
Now Goodridge hoses with banjos to fit Thumbs up
Cjwatson27
Post #2182
Looking good mate bet those pedals will take some getting used to
Posted 8th Feb 2019 at 17:52
Post #2183
quote:
[quote="Cjwatson27"]Looking good mate bet those pedals will take some getting used to
That’s the last of my worries Chris ..:LOL ....The way it’s going ....I’m going to need to get used to the whole blooming car again LOL
But yes your right ...didn’t have a choice as I need a hydraulic clutch for my Sequencial box m8 .
Posted 8th Feb 2019 at 18:30
Post #2184
Old Dampers uprated to 4ways .....with new springs / no progressive springs anymore / helper springs instead ...
Posted 12th Feb 2019 at 09:46
Post #2185
Remote canisters now ...
Posted 12th Feb 2019 at 09:47
Post #2186
Small up date ...fitting a Spooks /engine Servo Vacuum pump blank as I’m running a pedal box as I need a hydraulic clutch for my Gearbox and I’ve removed the Servo also .
Before
Posted 13th Feb 2019 at 16:11
Post #2187
Removed
Post #2188
Spooks blank with (O ring seal )
Another 1.6kgs removed also ....bonus LOL
Posted 13th Feb 2019 at 16:13
Post #2189
For those of you that haven’t removed one ?
Runs off the cam
Posted 13th Feb 2019 at 16:14
Post #2190
Always good removing things not needed LOL
Posted 13th Feb 2019 at 16:15
Post #2191
Small update ...
Pedal box all piped up Thumbs up
Posted 15th Feb 2019 at 02:39
Post #2192
Getting somewhere now ....Pedal box bolted the the chassis rails and alloy cover plate changed a little and rear fixing silver panel screws now out the way at the front ...
Just got to bleed the brakes and wait for my Sequencial Gearbox to arrive in the next 10days to fit and bleed the clutch also...
Got to get rid and rewire below the dash above the pedal box.... sometime this year ? ....like the idea of Ryan Ennion’s centre console power keypad with wipers / lights etc all in one place ...that’s not a five minute cheap job so it will have to wait LOL
Posted 17th Feb 2019 at 16:12
blandy
Post #2193
That cartek dash Ryan runs is a beautiful bit of kit. If I wasn’t tight it’s what I would have. So clean and simple
Posted 17th Feb 2019 at 21:39
Post #2194
quote:
[quote="blandy"]That cartek dash Ryan runs is a beautiful bit of kit. If I wasn’t tight it’s what I would have. So clean and simple
Yes I agree Mike Thumbs up ....
Posted 18th Feb 2019 at 06:14
Post #2195
Small update ...
I run the same TTV (trigger less) flywheel already but mines a little worn ...my one now is fine but you know LOL
Big thank you to Tony Palfrey of Maxi Motorsport for sorting me out Thumbs up
Posted 18th Feb 2019 at 19:16
Post #2196
Much happier the foot rest is cut down and fixed ...
It all removes with the pedal box cover for easy access
Posted 22nd Feb 2019 at 16:47
Post #2197
All alloy and bonded as well as bolted ..it’s solid
Post #2198
Feels 100% better now and o think looks better for what that’s worth?
Posted 22nd Feb 2019 at 16:49
blandy
Post #2199
Getting Closer soon be back out on track
Posted 22nd Feb 2019 at 19:32
Post #2200
quote:
[quote="blandy"]Getting Closer soon be back out on track
Fingers crossed Mike ...10 days for the box to come Thumbs up
Posted 22nd Feb 2019 at 19:54
