displaying posts 2276 to 2300 of 3424
Pages (137): first .. 91 [92] 93 .. last
Post #2276
This one
Posted 6th Jun 2020 at 01:05
Post #2277
And this
pete_rallye
Post #2278
Could really do with updating my car to something like this, it uses aircraft rcd's as combined swtiches and rcd's so its like a primitive form of what you have.
Not sure I could make use of 16 switches though! One of the 8 switch ones along with a solid state isolater would be nice though.
Lap of the 'ring
Posted 18th May 2019 at 07:53
Post #2279
That makes sense Pete ...I’m going from sort of standard in side as I said earlier but I did strip lots out but nowhere near enough Pete
I run a Sandy Brown engine loom which connects into my existing standard loom somewhere I can’t remember but that can be modified if need be ...
I’ve got so much standard wiring under the wings and engine including the under dash and under bonnet standard fuse box LOL
I recon I will end up using 12-14 channels =
1 standard headlights
2 high beam
3 left hand indicators
4 right hand indicators
5 rain light
6 slow wipers
7 fast wipers
8. Start
9.fuel pump
10.Horn
11.ignition ..dash dial power ...Ecu etc
12.hazards
13. fan manual override if needed
14. GoPro
The solid state tiny XR isolation they do with remote neg cut is the way I’m also going Thumbs up
I’m also going to possible run a wireless Cartek steering wheel button system with Indicators / horn / GoPro / headlights
Posted 18th May 2019 at 09:51
Post #2280
Another update
Removed the bell housing adaptor plate from the Sequencial box
Posted 6th Jun 2020 at 01:06
Post #2281
Sequencial box adaptor plate fitted so I could measure from outface to Twin plate clutch fingers
Post #2282
I’ve struggled over the years and borrowed other people’s ...NO MORE ...I’ve had enough LOL LOL
Pushed my cluctch trumpet into the bearing with easy ..no effort at all Thumbs up
And pushed it back out after measuring everything......
sageman
Post #2283
whats with the links do the forum no longer accept "bbcode"
edit:
you can link the direct pictures from flickr
on your picture click the arrow going to the right (the one in the middle) on the bottom right
click bbcode
select size
copy link
delite everything outside of the [img].....[img] part
the result being...
sorry to hijack here a little
1976 Reliant Kitten
1985 Reliant Fox Tandy campervan
1998 GTI-6
1993 Citroen XM sei V6 (barn find)
Posted 19th May 2019 at 15:34
sageman
Post #2284
ahh i see
no you cant do it from the app
1976 Reliant Kitten
1998 GTI-6
Posted 19th May 2019 at 18:26
Post #2285
sageman wrote:
ahh i see
Thought so Thumbs down
Thank you for trying Thumbs up
Posted 19th May 2019 at 18:31
Post #2286
Temp fitted the dash and connected it up temp also ...not sure which screen I’m going to choice yet ...lots to choose from
Posted 6th Jun 2020 at 01:07
Post #2287
Fitted the bearing and clutch hydraulic trumpet today
Post #2288
Fitted it temp
Posted 6th Jun 2020 at 01:08
Post #2289
In = blue stainless
Bleed = red stainless
Post #2290
All fitted up
Posted 6th Jun 2020 at 01:09
Post #2291
As you can see I’ve had the bell housing anodised blue
Post #2292
Here we go !!!!!
Removed the subframe and got ready to in stall the gearbox Thumbs up
Post #2293
The Gearbox jack has made it so much easier
Posted 6th Jun 2020 at 01:10
Post #2294
Getting there LOL
blandy
Post #2295
Gotta have another passenger ride in this lol... make it longer then the last one though lol
Going to be mental when it’s finished true credit to you Damien.
Posted 8th Jun 2019 at 21:16
Post #2296
Nice! Thumbs up
Posted 9th Jun 2019 at 13:52
Post #2297
Big thank you Mike Thumbs up
110% yes !!!!
Posted 9th Jun 2019 at 18:56
Post #2298
prism7guy wrote:
Nice! Thumbs up
Thank you Steve Thumbs up
Posted 9th Jun 2019 at 18:57
Post #2299
New Garage roof electric winch ....
As you may know I’m running a Maxi Motorsport/ Tony Palfrey TTV twin clutch plate with my Sequencial box ...because it sticks out a bit more it’s making fitting it a little more tricky ...so it’s easier to drop the subframe and then electric winch the engine down 12inches ....it will be a doddle with the gearbox jack ....I Can then winch the whole lot up and get the correct place to fabricate the solid engine mount & this way I can also fabricate the top new cambelt side engine mount ...solid again ...when the engine is down out of the way ...I don’t even have to remove the Manifold....
In these pictures...Remember the car is up on the ramp and is 2 foot off the floor making it easier Thumbs up
Posted 6th Jun 2020 at 01:11
Post #2300
Makes it a one man operation now and almost easy LOL
