Do I need a new thermostat housing (black plastic part) or a new rad hose?
| Author | Subject: Coolant leak |
6box
Newbie Location: Norwich Registered: 23 Jan 2014 Posts: 41 Status: Offline |
I have a coolant leak coming from the thermostat area. It seems to be coming from the joint between the hose and black thermostat housing. I changed the o ring/ seal on the end of the hose but it's still leaking. Do I need a new thermostat housing (black plastic part) or a new rad hose? |
probably needs a new thermostat seal if the plastic part is intact.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
6box
I've changed the thermostat recently so replaced this then. Just to clarify there is only a seal that sits round the actual thermostat, a metal gasket between head and metal housing and Then just the O ring on the end of the hose? Or am I missing a seal somewhere? |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Take some pics bud may help________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
6waysforward
Seasoned Pro Location: Benfleet essex Registered: 30 Oct 2005 Posts: 3,168 Status: Offline |
6box wrote: Just to clarify there is only a seal that sits round the actual thermostat, a metal gasket between head and metal housing and Then just the O ring on the end of the hose? Either you put the new thermostat seal on dry and its snagged up while pushing in the hose. Make sure that the metal end of the rad hose is clean and not rusty. Clean it up or get a new one if not. Of the Black plastic elbow has a hairline crack which opens up when warm. I recently had this, took me ages to find it. ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
