Author Subject: Oil temperature sensor thread size
demondriverdan
Anyone know what the thread size is for the oil temp sensor in the sump? Not sure how to wire up the existing one with my data logger so want to get a replacement.
Rallye Race Car
Posted 9th Feb 2016 at 23:18
14x1.25 or 16x1.5.
easy to wire up, single wire from the dash, earth is body of the sender same as coolant temp.
not usually the same resistance range as the aftermarket gauges though
Posted 9th Feb 2016 at 23:23
demondriverdan
From looking at the manual of my data logger (Race Technology DL1 CluCool I might need a resistor but no idea what size to get the right values?
Rallye Race Car
Posted 9th Feb 2016 at 23:25
demondriverdan
Any idea whether mine would be an M14 or M16? Need to get a thread adapter to work with the aftermarket sensor.
Rallye Race Car
Posted 10th Feb 2016 at 09:45
demondriverdan
Failing that, is it a Bosch sensor? Found some info that they need a 1000ohm resistor to work properly
Rallye Race Car
Posted 10th Feb 2016 at 10:06
1131 A6
NFP
01
TEMPERATURE SENDING UNIT
14X125 165 DEG
BE- - BLUE
I believe its a Jaeger unit.
Posted 10th Feb 2016 at 10:29
demondriverdan
That's a pain. I'm not sure how to find out what resistor it needs to get the right values.
Rallye Race Car
Posted 10th Feb 2016 at 11:46
check its resistance across a few temperatures, and compare it with what resistances you need.
Posted 10th Feb 2016 at 11:59
