Author Subject: Passenger side door check strap
ben1024
Hi,
I am looking for a check strap for the passenger door of my Gti6, anyone from here has one they are willing to part with?
Cheers.
Posted 16th Mar 2016 at 09:00
jord294
Still available from maindealer
Posted 16th Mar 2016 at 09:18
mik
Check (see what I did there) if you need the whole check strap or just a pin. There are two types depending on the age of the car. One is an entire check strap with the pivoting part a rivet, the other is a two piece version held together with a roll pin. The roll pins do break eventually. I thought I needed the entire chec kstrap as it looked as though it was missing, but it turned out it had retracted itself into the door. I extended it, tapped into place a new roll pin from the dealer, job done!
Cherry Rallye SOLD
Posted 17th Mar 2016 at 09:22
ben1024
Cheers for the advice, the strap is still in one piece I think it either has some play on the pin or has cracked slightly (which is what happened to my 406 coupe strap). I checked the bolts and they are tight, the problem I have is the common knock that the door does when you open it. I thought it would be easier to change the whole thing but I will have a closer look tonight at the car to see whether I need to change only the pin or the whole thing
Posted 17th Mar 2016 at 10:03
probably just the pin needs changing
9181 63 DOOR STRUT PIN
can't remember if the later type has a roll pin or a solid steel pin.
theyre £3 odd, so I'd be measuring and seeing if I could get an alternative, or replacing the whole checkstrap assembly.
Posted 17th Mar 2016 at 10:33
alcon
I replaced both my door stays last year and they cost £66.77 from the main dealer. Quite expensive but made a massive difference to the opening and closing of the doors...ie no clunking anymore!
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 18th Mar 2016 at 13:57
