Author Subject: Fitting Drivers Door
oliverharveyuk@hotmail.co.uk
I am getting a replacement drivers door this weekend as my current one has a couple of nasty dents.
Just looking for the best way to go about fitting the door and making sure it aligns the same as the old one?
98 Blaze 6 - Current
Posted 30th Mar 2016 at 14:18
remove the hinge pivot bolt rather than the hinge from the door, it'll be much closer then to start with.
Posted 30th Mar 2016 at 14:28
The way I have done is like follows:
Get one (hopefully two helpers)
Sit in the drivers seat,
get them to hold some of the weight of the door,
Unscrew doors from body (ideally mark around the brackets with tippex)
Then get them to bring the door to you and line it up,
Get it as close to as it was as possible then do it up fairly loosely and gently close the door to see how it lines up.
You can make quite a bit of adjustment by slackening off the mountings and then rotating up down/pushing or pulling away form body.
Its basically trail and error, Once it's right, Tighten up all the way.
Posted 30th Mar 2016 at 14:29
Or that.
Which is probably easier.
Posted 30th Mar 2016 at 14:30
When you say hinge pivot bolt you mean this:
oliverharveyuk@hotmail.co.uk has attached the following image:
Posted 30th Mar 2016 at 14:49
yup.
Posted 30th Mar 2016 at 14:57
Thanks I'll let you know how I get on. So glad I joined this forum full of wisdom!!!
Posted 30th Mar 2016 at 15:02
oliverharveyuk@hotmail.co.uk wrote:
Thanks I'll let you know how I get on. So glad I joined this forum full of weirdos!!!
Posted 30th Mar 2016 at 15:21
cully
if you undo the pivot bolt the door will not fall off, as the lower hinge is cone shaped into the top hinge part
Posted 30th Mar 2016 at 16:45
I got a new pair for mine and did it on my own by undoing the hinge pin bolt.
The hardest part turned out to be reconnecting the door loom connector.
Posted 30th Mar 2016 at 22:17
