Author Subject: Window switch
oliverharveyuk@hotmail.co.uk
I have just replaced my ph2 '98 door with a ph2 '97 door however the pins for the window switch are different. My old door had a loom with 7 pins and my new loom only has four. So my window switch/mirror adjuster doesn't work. I need to fix my the loom between the car and the door to hopefully sort the failed central locking but am I gonna be surprised with more electrical differences? Also is it as simple as getting a 4 pin window switch to resolve the issue? I swapped the door to save money on body shop dent repairs but am I better off biting the bullet and putting the old door back on?
98 Blaze 6 - Current
Posted 4th Apr 2016 at 00:56
Puggitt
Why not swap the loom over? Not a hard job really as long as you can bend your arm in funny directions
Posted 4th Apr 2016 at 03:58
tvrfan007
As above, loom swap is the way forward.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 4th Apr 2016 at 06:40
How do I go about swapping the looms over? That may fix the issue with the window switch but might it cause issues with other stuff in the door that would be using a newer loom and potential pin layout like the window motor and central locking? Also there is a box riveted to the door that then goes to the window switch and mirror control does this need to be drilled off?
Posted 4th Apr 2016 at 07:39
cully
97 to a 98 car loom will be different too i suspect
as one has the security box under the rear seats central locking only unit
98 has the security unit in the lower dash locking/alarm combined
that year is ph2-ph3 wiring changeover
putting the wrong door switch in a ph2 with the relay box in the door will blow a fuse Wink
you will need to fit your original door loom to match your car loom Thumbs up
Posted 4th Apr 2016 at 07:46
mocinim
Best to refit the lot chap its time consuming but probably the easiest way its not hard just a little tricky
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 4th Apr 2016 at 08:50
So I can replace the loom but leave the window motor and door latches on and it should all work? And I thought this would be a simple door off, door back on job... Crazy
Posted 4th Apr 2016 at 09:32
cully
the plugs may be different on the ph 3 motor but just join the ph3 plug in your old Ph2 loom
i had to do that when i changed the window mech from ph2-3 motor
Posted 4th Apr 2016 at 10:06
not read this properly but just check about the auto window switch - i stuck a p3 window switch from a gti6 onto my hdi and it kept blowing fuses because the gti6 had another pin for the auto option
Posted 4th Apr 2016 at 11:24
Okay I will swap the looms over tomorrow and hope that resolves it. What do you mean by putting the phase 2 window motor plug on the ph3 loom? As in cut and solder on? It looks like it may have blown a fuse to as now the passenger side windows aren't working :/
Posted 4th Apr 2016 at 22:48
Puggitt
The drivers door and window switch is part of the circuit for the passenger window, so without it all connected the passenger side won't work Thumbs up
Posted 4th Apr 2016 at 22:58
cully
ph3 window motor has a different plug to a ph2
you may have to change the loom motor plug over for your new door
Posted 5th Apr 2016 at 06:13
Just wanted to say thanks for the help changing the loom worked a treat!
Posted 5th Apr 2016 at 19:59
