Author Subject: HELP!!!! Car not starting after engine change
Right guys i'm stuck!
Recently swapped an engine over for a friend as his old one dies due to a bottom end rattle. After swapping engine over etc we started the car up and it run first time. After stopping the car it would not start again for some reason.
After investigation it turns out that the fuel pump will not prime,now i've read up and several posts point to the dual fuel relay. However this was swaped out for a known working one and still no joy Sad
Any ideas? im thinking possible ECU issues?
Ash
Posted 6th Jun 2016 at 11:04
mocinim
Change the relay again bud may have died
Im guessing you checked the fuses Smile
Possible starter motor ???
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 6th Jun 2016 at 11:23
was the ECU hard unlocked? or was it just swapped without ECU being touched?
Posted 6th Jun 2016 at 11:34
Ive tried 2 different relays and both were working fine before engine swap. yeah all fuses checked to ruile that out and it wont be the starter as its not getting fuel up to the fuel rail
Swapped without being touched.Could not soft unlock it as it was being fitted to a car witha dead battery
Posted 6th Jun 2016 at 11:58
check the central locking fuse.
Posted 6th Jun 2016 at 12:12
cheers dude will do Thumbs up
Posted 6th Jun 2016 at 12:14
mocinim
Did it start ???
Posted 7th Jun 2016 at 17:58
