Author Subject: Rear Wheel Stud Conversion
RetroPug
A set of 8 wheel studs for the rear axle. These may also be a good length for the front, but I do not know this, I also do not have wheel nuts for these. I removed them from an axle they came on and I use wheel bolts so these are surplus to requirements.
Make/material are unknown.
10 pounds for the set collected from Warwickshire, or Pugfest. Postage possible also, probably not expensive as they'd go in a padded envelope.
Posted 26th Jun 2016 at 14:22
jeffers Forum Admin
Are these standard length or longer?
Team Running Engine again!
Team Negative Camber!
Posted 26th Jun 2016 at 14:51
I personally feel ....80mm from hub face out is the best size to have ..:that way you can use upto 25mm spacers Thumbs up ....I use 15mm only on the fronts for my inside tyres to miss my suspension springs ..
But you can change offsets of wheels better with more flexibility to ,..
Posted 26th Jun 2016 at 17:14
RetroPug
Good question. I will measure them.
Posted 26th Jun 2016 at 17:22
Measured a spare one this morning Thumbs down
My mistake mine are 80mm total & have 60mm of showing thread after they are loctite & screwed 20mm into each hub ...
I've included the starting unthreaded / smooth end in the 60mm /80mm length Thumbs up
Posted 27th Jun 2016 at 09:27
RetroPug
The ones I have for sale are 60mm in total length.
Posted 27th Jun 2016 at 21:12
RetroPug
Bump.
Posted 2nd Jul 2016 at 09:37
RetroPug
Bump. Still got these.
Posted 30th Sep 2016 at 19:20
RetroPug
Bump.
Posted 14th Oct 2016 at 23:47
RetroPug
Still for sale.
Posted 12th Nov 2016 at 08:15
