Author Subject: xu10j4 on gti management
Puggered
While I'm sure it's been done, can't seem to find any info on it.
I have a spare Mi16 S2 engine along with spare gti ecu (unlocked), sensors, loom and manifolds.
are there any specific issues, pitfalls etc?
Posted 4th Jul 2016 at 14:21
The RFY engine doesn't have a map sensor, its onboard the ECU taking a vac signal from the front of the intake plenum.
The RFS doest have the 12v output for the ACAV solenoid either.
The RFY coils are 3 wire externally driven by ignition amplifiers, RFS 2 wire coils dont fit and are directly driven from the ecu
otherwise afaik the rest of the sensors will work, crank and knock sensors TPS IAT etc work in the same way, also the cam sensor.
it may well work on an RFS inlet but I doubt the ecu will have an ideal map, also you'll have the faff of making the oil pipework fit around the different inlet.
Posted 4th Jul 2016 at 15:10
IvayloPavlov
With RFS manifold can be happen.There is big difference between the TBs.ACAV engine is with 3 wire idle valve,GTI6 is with stepper.I believe that the GTI6 runs fully sequential,but older one semi.
Posted 4th Jul 2016 at 18:28
Puggered
Had a quick look at it and it does seem like things will fit, even the loom is pretty close.
I'll have to have a closer look at the coils though.
did you get PP2k sorted?
Posted 4th Jul 2016 at 23:44
Puggered
I would use all RFS sensors, icv, loom and ecu. So it would be sequential.
Posted 4th Jul 2016 at 23:47
IvayloPavlov
What about the injectors?RFS use 265 cc, RFT/Y 195 cc.
Posted 5th Jul 2016 at 05:44
Puggered
definitely the gti injectors.
measured up the gti coils, if you cut the mounting tabs off and swap the boot then they fit quite well
Posted 5th Jul 2016 at 12:19
what about the map?
Posted 5th Jul 2016 at 12:39
IvayloPavlov
With GTI manifold there will be no issue in my POV.
Posted 5th Jul 2016 at 19:25
cams port flow valve sizes compression ratio exhaust flow is all different...
Posted 5th Jul 2016 at 20:24
Puggered
Always the voice of reason Welsh LOL
Do you really think port flow is going to be that much different?
It'll need a remap regardless no doubt.
Posted 6th Jul 2016 at 00:25
