Is that a good price as I haven't looked in to the prices from peugeot...
| Author | Subject: SNR rear axle bearings |
devere
Senior User Location: Saxtead Registered: 16 Dec 2008 Posts: 810 Status: Offline |
Has anyone bought the snr rear aeck bearings advertised on eBay? Seem to be about 23 quid.Is that a good price as I haven't looked in to the prices from peugeot... |
jord294
I'm still using the genuine kits from Peugeot. 5132.62 ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Peugeot/citroen kit is about £30 for both sides with the large black seals, however if you need bearings chances are you need the shafts too so might as well buy the full kit ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
devere
jord294 wrote: I'm still using the genuine kits from Peugeot. 5132.62 Is hat the full kit of bearings and seals for 1 side with that part number? And yes Mei, totally possible il need shafts. Not had it apart yet to check them. Are they good dealer prices or eBay the way to go? |
miki4
Regular Location: Cologne Registered: 09 Nov 2015 Posts: 393 Status: Offline |
Hi guys,what is the seal 'C' for in the diagram ('B' in second pic) and where does it belong? It is contained in the OEM bearing kit 5132.62 for 'IMPROVED SUSPENSION' but not in the kit 5131.45 for 'XU/XUD AND NORMAL SUSPENSION' so it should be fitted in an GTI6 axle, I guess? EDIT: s**t, forgot the pics... miki4 has attached the following image: |
miki4
Pic2miki4 has attached the following image: |
miki4
You can see a pic of that seal in this ebay ad:http://www.ebay.co.uk/itm/CITROEN-ZX-PEUGEOT-306-Original-513262-Repair-Kit-Rear-Wheel-Suspension-/310984567066 |
miki4
No-one? Where are the rear beam pros? |
never seen those on any beam I have taken apart and they're not in the aftermarket SNR kits I use.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
miki4
Never seen that either on any pic of rear beam rebuilds. Weird. But there are two SNR kits available. One is KS559.00 which probably is what you use then and equals the OEM kit 5131.45. According to Service Box this one is for 'XU/XUD AND NORMAL SUSPENSION' and does not include that special seal.SNR KS559.08 equals the OEM kit 5132.62 and is for 'IMPROVED SUSPENSION'. It additionally includes the mysterious seal. This is what I found out. Jord wrote that he uses the 5132.62 kits so he could have come in contact with the seal before? |
marksorrento205
Seasoned Pro Location: Airborne in the lanes Registered: 26 Aug 2008 Posts: 2,228 Status: Offline |
I have had genuine kits with that seal and fitted them as per the drawing above. Personally I found them to be a pain in the arse with no logic to why they are there. Also found the trailing arm shaft needed to br tapped in rather than just sliding in nicely. I relocate them to the bin now. 205 / 309 / 306 did not seem to come from factory with them fitted as said above. Would love to hear an explanation as to what there purpose is though ________________________________________ How to do a clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
miki4
Thanks for the confirmation! I also cannot explain what its purpose could be. Looks like it protects the inner bearing but if water and dirt ingress damages the outer bearing it's pointless. |
