Author Subject: HELP with v6 cambelt
Cjwatson27
Hi having issues with changing the cam belt on the v6 I've order a replacement belt kit and the garage say it's the wrong one something about mine having a auto tensioner and the kit having a manual one. They also say the cam belt doesn't need replacing has its been replaced recently has all the writing showing still on the belt. What do you guys think should I replace it and do I have the right can belt kit and the tensioners a revised item ?
Posted 25th Jul 2016 at 11:23
you can fit the manual tensioner but need to mod or replace the water pump too.
Posted 25th Jul 2016 at 13:04
mocinim
Get the correct kit bud how long has it been sitting around at your lock up personally id change it
Call the place you got it from see if they will exchange it
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 25th Jul 2016 at 13:12
mocinim
If the tensioner is new as is the belt id just change the belt bud
Posted 25th Jul 2016 at 13:13
Cjwatson27
I've got a new water pump would that already work or do I need to order a later one ?
Posted 25th Jul 2016 at 13:32
Depends on the belt and tensioner you've bought.
All early stuff works together, all old stuff walks together. Peugeot, Citroën and Renault
Posted 25th Jul 2016 at 21:09
You need the later pump but with the earlier larger diameter vane on it. (There's 3 pumps, early tensioner large vane, late tensioner large vane, late tensioner small vane).
Or, just do what I did and chop the bit off the early pump that gets in the way of the late tensioner setup (since it's very difficult to get the early tensioner setup for reasonable money and the late one works fine and is simpler)
Posted 25th Jul 2016 at 21:14
Cjwatson27
Such a ball ache this is becoming
Posted 25th Jul 2016 at 21:47
Did one of these in a 406 coupe for the first time a while ago. Was surprised how many cats you could swing between the inner wing and the belt once it's stripped.
Posted 25th Jul 2016 at 21:54
Cjwatson27
Not much room in the v6 once it's in the 306. Just want it finished now
Posted 25th Jul 2016 at 22:27
If you've already got the water pump all they need to do is chop off the bit where the big hole for the old tension fits, and the new one will go in then.
Posted 25th Jul 2016 at 22:51
LIke this:
Posted 25th Jul 2016 at 22:56
Cjwatson27
Cheers Phillip I'll show him that. Problem is he's a ford man so he's only used to rust and cast iron lol
Posted 25th Jul 2016 at 23:01
Cjwatson27
Cheers looks like I have a new style water pump and belt kit. Well the belt and tensioner looks brand new the water pump looks old and has a leak so it's getting changed over so fingers crossed
Posted 28th Jul 2016 at 14:27
I've got my fingers crossed for you Thumbs up
Posted 28th Jul 2016 at 15:34
