Author Subject: Cold air feeds
potpot
Anyone got any pics of cold air feeds for throttle bodies on their 6 or rallye, trying to get some ideas together?
Posted 17th Aug 2016 at 19:39
bit of a work in progress working with what I have to hand and not much money, a 205 rad and some aluminium faced foam board metal bracketry and threaded rod.
oh and its a ZX, so not too dissimilar to a 306.
Posted 17th Aug 2016 at 21:07
LOL how cagy are those shots I could be looking at anything there!
Take a step back and show us the fuller picture!
Posted 17th Aug 2016 at 21:17
Haven't got any more, not much more to see really!
other than a ropey looking zx...
Posted 17th Aug 2016 at 21:39
Cjwatson27
How many fans do you have on your 205 rad wp ?
Posted 17th Aug 2016 at 21:44
none yet, will be using one Spal 9" pusher, should be sufficient.
the radiator core is about 60mm shorter but the same width and thickness as a 306 rad, just a bit of a faff to sort the coolant pipes, especially if you want to keep the heat exchanger.
I know quite a few higher powered cars running standard nissens 205 rads without any cooling issues
Posted 17th Aug 2016 at 21:49
Cjwatson27
Good to hear my v6 has a 205 nissens and just one fan. Just unsure if it was up to the job
Sorry for the thread hijack
Posted 17th Aug 2016 at 21:54
Chr1sch
Looks smart, I'm having a Richw flywheel and new clutch at the moment but along with welding, bodies are absolutely on the list!
Are you running cams too?
Posted 18th Aug 2016 at 08:07
every engine has cams unless its a solenoid operated valve Razz
see my project thread
Posted 18th Aug 2016 at 13:22
ok fot a road car, will struggle on track, oil cooler will help
Posted 18th Aug 2016 at 13:23
potpot
Any more pics anyone?
Posted 18th Aug 2016 at 18:51
Chr1sch
Im running a Nissens rad, one fan (on high) and a smallish (12 row) oil cooler and even on hot days im not having any temp issues
Posted 19th Aug 2016 at 11:05
Twangy
made cold air box feed for my throttle bodies ,
Twangy has attached the following image:
wayne mcardle
Posted 21st Aug 2016 at 08:52
pug_306
You could of made your airbox a bit bigger wayne lol. Looks really good buddy :-)
1992 205 GTi6
205 Turbo 340bhp
Posted 21st Aug 2016 at 09:23
