Author Subject: 9730 AA to 9730 AG Gearbox oil
deeturbo
Hi,
The gearbox oil from Pug is now 75w rather than 75w80.
Has anyone tried the 75w and is there any noticeable difference in gear selection, smoother?
Posted 27th Aug 2016 at 10:47
cully
yes I am using it i've noticed no change
Posted 27th Aug 2016 at 11:10
deeturbo
Have you used it over winter to?
Posted 27th Aug 2016 at 11:13
cully
no only since ive fitted the ATB in june
Posted 27th Aug 2016 at 11:14
deeturbo
I wonder what the reason for them to change it was?
Posted 27th Aug 2016 at 11:19
more mpgz.
its still the right spec for the synchros etc, but a bit thinner and less stinky
Posted 27th Aug 2016 at 11:24
deeturbo
Talking about thinner oil, I'm running 10w40 at the minute in the engine and I've changed a lot of seals as some were weeping. With the better seals I should be ok to run thinner oil without the issue of leaks.
I was thinking of using 5w30, is it ok to use for normal road use in these engines and should I see a slight increase in MPG with it?
Posted 27th Aug 2016 at 11:38
Oil wont increase MPG and i'd be sticking to 10w 40 myself on a standard car
Posted 27th Aug 2016 at 11:56
cully
GTI6 is not about MPG!
Smiles per mile is my aim Wink
Posted 27th Aug 2016 at 12:41
mocinim
I use 5w30 in my black rallye had it rebuilt and only use it at night
Helps a little with cooler temperatures
But for daily id use 10w40 or 5w40 in winter
W30 is to low for general use especially if its your daily
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 27th Aug 2016 at 13:29
jeffers Forum Admin
10w40 semi is the correct oil for these engines so why would u want to change?
Team Running Engine again!
Team Negative Camber!
Posted 27th Aug 2016 at 13:27
deeturbo
Oops meant 5w40, Total QUARTZ 9000.
My thinking was slightly thinner oil being easier for the engine to pump round.
Posted 27th Aug 2016 at 15:38
deeturbo
I do like to keep an eye on MPG as it does tend to show up some issues early.
At the moment I'm getting 35mpg on spirited drive to work. It's a shame it motorway mostly and not country roads like it used to be.
Posted 27th Aug 2016 at 15:51
