Team SUPERCHARGED
I LIVE FOR THE 306
Old Project thread
| Author | Subject: Big brakes...of some description |
manthos
Seasoned Pro Location: Norwich Registered: 29 Apr 2009 Posts: 1,966 Status: Offline |
Good lad £150 just for discs when you need new ones________________________________________ Team SUPERCHARGED I LIVE FOR THE 306 ![]() Old Project thread Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url = |
aaron6
Where did you find them for £150? Hi spec want nearer £300 and compbrake want even more.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
manthos
150 per side________________________________________ Team SUPERCHARGED I LIVE FOR THE 306 ![]() Old Project thread Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url = |
manthos
éter learn how to go round corners without breaking________________________________________ Team SUPERCHARGED I LIVE FOR THE 306 ![]() Old Project thread Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url = |
aaron6
Yeah that's the price I found. I'll use the rotors then depending on my cash flow at the time they need replacing I may buy more or make a bracket so I can run the 305mm 406 coupe disc________________________________________ See the sheer power and might of the lesser known burrowing owl. |
manthos wrote: éter learn how to go round corners without breaking *Braking. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
aaron6 wrote: Yeah that's the price I found. I'll use the rotors then depending on my cash flow at the time they need replacing I may buy more or make a bracket so I can run the 305mm 406 coupe disc Fiat Punto EVO Disc goes on with the pendulumn bracket if the pcd is redrilled and the centre bore taken out, Niall on the OC did it. weigh a fecking ton mind, about the same as the 406 disc but have more offset so you'll have a chance of bolting more wheels over them. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
sergioiacobucci
Senior User Location: High Wycombe Registered: 27 Nov 2007 Posts: 526 Status: Offline |
welshpug! wrote: manthos wrote: éter learn how to go round corners without breaking *Braking. ![]() ________________________________________ Phase 1 silver track car335i daily |
Grammar ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
sergioiacobucci
Post #35
Haha.I just found G88's (pair) for £210 delivered. Think that's pretty good. ________________________________________ Phase 1 silver track car335i daily |
aaron6
Post #36
Not a bad price.That was the citroen xantia V6 I take it? 288mm discs ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
aaron6
Post #37
welshpug! wrote: Hmmm... I may look into that then seems as I'm a toolmaker that should be dead easy aaron6 wrote: Yeah that's the price I found. I'll use the rotors then depending on my cash flow at the time they need replacing I may buy more or make a bracket so I can run the 305mm 406 coupe disc Fiat Punto EVO Disc goes on with the pendulumn bracket if the pcd is redrilled and the centre bore taken out, Niall on the OC did it. weigh a fecking ton mind, about the same as the 406 disc but have more offset so you'll have a chance of bolting more wheels over them. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
manthos
Post #38
Aaron without the bells you will get squeel again________________________________________ Team SUPERCHARGED I LIVE FOR THE 306 ![]() Old Project thread Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url = |
aaron6
Post #39
manthos wrote: maybe not, the 406 coupe disc don't squeel with the Renault brembos Aaron without the bells you will get squeel again ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Post #40
yeah renault brembo's don't tent to squeal at all, probably due to being a much stiffer monoblock design.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
sergioiacobucci
Post #41
welshpug! wrote: yeah renault brembo's don't tent to squeal at all, probably due to being a much stiffer monoblock design. *tend sorry I had to.... ________________________________________ Phase 1 silver track car335i daily |
manthos
Post #42
+1 for Sergio, got you there welshy ________________________________________ Team SUPERCHARGED I LIVE FOR THE 306 ![]() Old Project thread Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url = |
3rd time lucky
Seasoned Pro Location: maidstone Registered: 23 Apr 2007 Posts: 1,879 Status: Offline |
Post #43
![]() ________________________________________ DIABLO GTI-6 - Legend - NILE GTI-6 - SoldCHERRY GTI-6 P1 SUPERCHARGED - Broken up BLACK RALLYE - Sold 205 Dturbo xud9 work horse - Dead CHERRY RALLYE - new toy |
sergioiacobucci
Post #45
Thanks mate. Thats a very good point, could be cheaper now but not in the long run________________________________________ Phase 1 silver track car335i daily |
demondriverdan
Post #46
What pads are you using that only last 3 trackdays?________________________________________ Rallye Race Car |
manthos
Post #48
the whole reason the welly designed the brackets for the wilwoods to fit is because of how cheap the discs and pads are to replace as he was doing lots of track days and they also give fantastic stopping power. my genuine brembo discs were £38 and the ds2500 pads were £70________________________________________ Team SUPERCHARGED I LIVE FOR THE 306 ![]() Old Project thread Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url = |
Post #49
My discs and pads have lots of life left and have done probably 8+ trackdays and 15-20 laps of the nordschleife. Rotors were circa £400 and pads around £250.If you can get them give carbotech xp8 pads a try, not managed to kill them yet and they've had a lot of abuse, 40+ mins on track at cadwell both when n/a and supercharged. False economy buying cheap discs and pads if they only last three trackdays in my eyes. ________________________________________ Goldie the track car. |
demondriverdan
Post #50
I use Carbotech XP8s in the race car and they last for a whole race season. That's 7 races and about 5 trackdays / test days which I think is near enough 1100 hard track miles.________________________________________ Rallye Race Car |
