Author Subject: Engine bay to fuse box connection
fast_eddie
I'm 3/4 of the way through pulling the dash out of the 6 and I'm a little stuck with what to do with the bulkhead connection through to the engine bay?
Does it split into two halves through the connection like a plug type set up or is that whole unit 'as one' and has to be pulled through from the passenger compartment?
Thanks in advance
Jon
Posted 6th Sep 2016 at 15:27
demondriverdan
Splits in two. From the engine bay you'll see the plug under the wiper motor (which I think you'll need to remove). You need to undo the centre screw, I think there's a cap covering it up, to separate the two parts of the plug
Rallye Race Car
Posted 6th Sep 2016 at 15:58
fast_eddie
Thanks
Ive removed that but cant seem to pull it apart. Ill try harder Smile
Posted 6th Sep 2016 at 16:47
demondriverdan
They're a pain in the arse to get apart sometimes, mine was a nightmare. It will eventually go though! I think I used some flathead screw drivers to help prise them apart
Rallye Race Car
Posted 6th Sep 2016 at 17:43
fast_eddie
Can someone please tell me which bit either 1 or 2 im supposed to prise apart?
All i hear at the moment is lots of creaking and cracking each time i try to lever it apart and i dont want to break anythingThumbs down
cheers
fast_eddie has attached the following image:
Posted 6th Sep 2016 at 18:17
pugheaven
Number 1.
Give the connector a wobble and as long as you have undone the torx bit in the middle under the cap it should come away...
Then you need to undo the 2 6mm nuts one in each corner diagonally apart to undo the internal part of the loom from the bulk head
Posted 6th Sep 2016 at 19:31
yeah, looks like you haven't removed the torx screw yet?
Posted 6th Sep 2016 at 19:54
fast_eddie
ok thanks , looks like ive been a Northern Monkey retard Sad
Posted 6th Sep 2016 at 23:19
fast_eddie
Yep full on Northern monkey retard!
Undid the centre screw(it was bunged up with debris so I couldnt see the torx head boltRoll eyes ) and it prised apart !
Dash is now out, thanks for everyone's help Thumbs up
Posted 7th Sep 2016 at 21:21
