Author Subject: Team Dynamics 1.2 Wheel Bolts
GTi6-PJL
As per the title, can anyone recommend the best bolts to use on these wheels (16 inch, ET 15). I've seen a few posts mentioning tuner bolts however most of the links are dead, and I don't want to buy the wrong ones!
Thanks in advance Smile
2000 W Phase 3 Moonstone.
Posted 11th Sep 2016 at 10:26
demondriverdan
You need tapered bolts rather than flat faced ones that come with Cyclones (and other wheels). Can't remember where I got mine from, think I took them from a car in a scrap yard!
Rallye Race Car
Posted 11th Sep 2016 at 10:39
c5 wheel bolts would work, anything with a 12x1.25 thread and a straight 60d taper seat.
Posted 11th Sep 2016 at 12:37
GTi6-PJL
Welshpug - thanks for that. I see the C5 bolts are 26mm long - I've found some tuner bolts which are 28mm - I assume these will be OK? Only looking at tuner bolts as I can source these far cheaper than the C5 bolts, plus they have the additional benefit of being harder to nick (in theory at least).
Posted 11th Sep 2016 at 18:40
janne l
I'd recommend going for 17mm hex, i find that the bolt holes are quite narrow, and my 19mm socket fouls on the inside.
Peugeot 306 GTI -97 Stripped out trackday toy
Peugeot 307 SW Griffe -05
Peugeot 206 1,6 Griffe -04
Posted 14th Sep 2016 at 10:53
get a wheel socket, they are slimmer
Posted 14th Sep 2016 at 11:09
Cjwatson27
In wouldn't use those McGuard bolts things either mine fell apart and had to be drilled off
Posted 14th Sep 2016 at 11:20
janne l
That's what i've got, still narrow Wink
Posted 14th Sep 2016 at 11:35
