Author Subject: Clutch fork bushes
mocinim
Hi gents one for in the trade guys how much are clutch fork bushes usually pug ones and aftermarket and is there much difference in quality cheers Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 21st Sep 2016 at 12:18
never bought aby aftermarket, only o.e.m and got a bag of them.
never seen a reliable well priced aftermarket source
Posted 21st Sep 2016 at 12:42
mocinim
How much is a bag ???
Posted 21st Sep 2016 at 12:52
depends how much of a discount your parts man gives you LOL
they come in 5s from the warehouse iirc, but thei will split the pack usually.
Posted 21st Sep 2016 at 13:05
silky
I've got these in the garage, not sure if they're what you need though
Posted 21st Sep 2016 at 13:18
mocinim
Will check the part number and get back to you cheers bud
EDIT : WRONG PART NUMBER BUD
TOP IS 2175 21
BOTTOM IS 2175 20
BUT THANKS ANYWAY BUD
Posted 21st Sep 2016 at 13:46
We have a transmission section for transmission related quiries Roll eyes
Posted 21st Sep 2016 at 14:12
GTi6-PJL
mocinim - I'll have a look through my receipts tonight as I had to buy some new ones last year Smile
2000 W Phase 3 Moonstone.
Posted 21st Sep 2016 at 14:44
mocinim
Agreed good sir was originally just after a general price detail
Perhaps you could enquire as to weather your good frinds in the admin department could arrange a location alteration due to the unexpected longevity of this now growing thread ?thanks muchley ?
Posted 21st Sep 2016 at 14:48
GTi6-PJL
Right, just had a look at my invoice from last year and found the following:
2175 54 - Fork Bearing £2.11
2175 55 - Fork Bearing £1.73
2175 56 - Protector £1.23
I've just confirmed these part numbers on ServiceBox too. Hope this helps!
Posted 21st Sep 2016 at 17:17
mocinim
Cheers bud thats quite interesting is yours ph3 not that it should matter and did they fit well
The numbers i put in above where supplied by my local peugeot garage and are referenced from my number plate going to have to investigate further cheers chap
Posted 21st Sep 2016 at 17:21
GTi6-PJL
I didn't fit the clutch myself but I didn't have any complaints about that (they did complain about my Miles gear linkages not fitting so they had to order some OE ones in, but that's a different story!)
The part numbers you posted appear to be correct too, as they're listed for "until RPO 08484", which being a phase 2 would probably be right - mine is a phase 3. There's no other part number for the fork lever itself, so I can't imagine there would be any issues however YMMV.
Posted 21st Sep 2016 at 17:36
those yellow bushes are only for J stamped push clutch forks pre april 1993, the length of the fork fingers is different and the bushes are offset to account for it.
the later bushes are white, the late phase 3 type retrofit to the earlier white bush shafts fine, they have an extended collar for the rubber seal.
Posted 21st Sep 2016 at 18:49
jeffers Forum Admin
You only need to ask, or to be fair start the thread in the right place in the first place! Anyway, moved! Thumbs up LOL
Team Running Engine again!
Team Negative Camber!
Posted 21st Sep 2016 at 21:24
mocinim
Cheers captain Smile
Posted 21st Sep 2016 at 22:13
mocinim
Any one know the part number for the clutch fork kit or just the clutch fork cheers Smile
Posted 10th Oct 2016 at 22:48
mocinim
2115 25 ??????
Posted 10th Oct 2016 at 23:00
check the link in your own signature LOL
Posted 11th Oct 2016 at 12:42
mocinim
Was going to but i keep getting locked out and have to make a new account
Its a pain in the arse
Plus i like to attempt to keep this forum busy
Most required detail can be found on here but if we all just came to read there would be very little chitty chat
Smile
But cheers anyway got this part number from one of your old posts cheers WP
Posted 11th Oct 2016 at 12:46
you dont want 2115 25, that's a push clutch fork, you need 2115 27.
Posted 11th Oct 2016 at 12:56
mocinim
Cheers bud
Posted 11th Oct 2016 at 20:25
