Author Subject: Injector removal?
sergioiacobucci
Had a little search around and cannot seem to find much detail. How hard is it to remove the injectors?
Phase 1 silver track car
335i daily
Posted 10th Oct 2016 at 08:31
two 10mm bolts and 4 plugs
Posted 10th Oct 2016 at 09:09
mocinim
What he said
Then pull give a wiggle nice n easy bud
Have some paper towel ready to catch fuel from the rail
There wont be a great deal but expect some
Then make sure u have all your seals Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 10th Oct 2016 at 09:15
sergioiacobucci
Cheers! Thinking about sending them off for a clean and getting new seals
335i daily
Posted 10th Oct 2016 at 10:54
as said i personally roll them around very gently and pull while you have them out might be worth checking them to see if their starting to perish!
Posted 10th Oct 2016 at 11:01
mocinim
In addition as always when trying to reinsert a rubber onto a tight hole a little bit of lube always helps
I find it easiest to attach them to the rail first lube the bottom ring and then just a wiggle and a poke Smile
Cleaning is a good plan also
Posted 10th Oct 2016 at 11:06
sergioiacobucci
Great thanks for the tips!
335i daily
Posted 10th Oct 2016 at 11:14
mr injector can sort out testing cleaning and new seals, about £40 all in and decent turnaround.
Posted 10th Oct 2016 at 11:18
mocinim
Any idea what sort of discounts he does for bulk loads
Posted 10th Oct 2016 at 11:21
sergioiacobucci
Yep was looking into them based on comments on this forum. He only just reopened due to relocation
335i daily
Posted 10th Oct 2016 at 12:23
