http://www.screwfix.com/p/easyfix-bzp-set-screws-m8-x-20mm-100-pack/12685
98 Blaze 6 - Current
| Author | Subject: Strut Brace Bolts |
oliverharveyuk@hotmail.co.uk
Regular Location: Banbury Registered: 16 Feb 2016 Posts: 231 Status: Offline |
I've just got a 2nd hand omp strut brace off ebay and looking through the forums you need longer than standard bolts to fit it. Seems you need m8 x 20mm so are these what I need? Also do I still use the standard washers?http://www.screwfix.com/p/easyfix-bzp-set-screws-m8-x-20mm-100-pack/12685 ________________________________________ 98 Blaze 6 - Current |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
yeah you can do mate! all they do is hold the suspension leg to the chassis as long as the bolt get enough purchase through the top hat plate it's all good! the washers will just stop you marking up the plate from the strut brace! ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Be careful on length they only need to be longer by a few mm obviously the same mm as the plate on the brace To long and you will risk grinding the top spring cup My white rallye came to me with this issue It destroyed the mount thread and all needs replacing ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Ah okay ill take one off and measure it then the plate width to check I won't be overdoing it with 20mm, I was more worried about strength and stuff don't want the bolt snapping on me... ________________________________________ 98 Blaze 6 - Current |
8.8 is fine, standard bolts are 8.8 iirc.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
6923 g6 is a 20mm long bolt with a captive wsher btw.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
That sounds perfect then, this is probably a stupid question but to buy that bolt using that part no. do I go through a Peugeot dealer? ________________________________________ 98 Blaze 6 - Current |
gnrlee
just googling the part no brings them up here's a place you could order them from online!________________________________________ Proud Member of the ASTOR Owners Club |
mocinim
welshpug! wrote: 8.8 is fine, standard bolts are 8.8 iirc. Yep 8.8 and 20Nm torque only !!! no need to tighten further even though they will easily they will thread out if you push it ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
The OE 16mm bolts on my top mounts were 10.9, but Phillipm said in this thread that the difference would not matter in this application. The 6923 G6 20mm bolt is listed as a water pump bolt and I got some from a Pug dealer From my project thread: mik wrote: ________________________________________ Cherry Rallye SOLD |
mocinim
mik wrote: The OE 16mm bolts on my top mounts were 10.9, but Phillipm said in this thread that the difference would not matter in this application. The 6923 G6 20mm bolt is listed as a water pump bolt and I got some from a Pug dealer From my project thread: Those 10.9 are probably from the subframe cup there almost exactly the same but 10.9 instead of 8.8 ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Thanks for your help lads, just ordered the bolts and a new oil cap cause mine was leaking even though it's barely 2 months old... should be able to get the brace on this weekend, happy days!! ________________________________________ 98 Blaze 6 - Current |
Thanks for the help lads, just fitted the brace with the new bolts and very happy with the outcome ![]() ![]() ________________________________________ 98 Blaze 6 - Current |
