Author Subject: Nyloc hub nuts
devere
Anyone on here using nyloc hub nuts rather than a castle nut and split pin?
If so do they hold up to the job fine and where did you get them from?
Seen them advertised a few places but first hand reviews always help.
Posted 5th Dec 2016 at 13:18
yes, Garry has them on his car, they'll be the same for yours.
I think Tom Fenton on the 205 forum has some, places like AB charge loads for them!
Posted 5th Dec 2016 at 13:24
devere
He sells them on there does he?
I shall see if I can remember my login for there and track him down!
Posted 5th Dec 2016 at 13:40
fatlapit
what size is the nut
Posted 5th Dec 2016 at 16:26
M24x1.5, I checked with Calvin and it was Tom indeed.
Posted 5th Dec 2016 at 16:52
fatlapit
hmmmm may have some @ work
Posted 5th Dec 2016 at 17:20
devere
So are they a specific nut, or without sounding too cowboy, will any m24x1.5 nyloc nut do the business?
Posted 5th Dec 2016 at 17:23
miki4
What's wrong with the original nut and split pin?
Posted 6th Dec 2016 at 00:39
its a faff when you want to change a shaft quickly in service and get back out without any time penalties.
Posted 6th Dec 2016 at 07:25
miki4
Sorry, I don't get it. I'm no native speaker. Can you reformulate your sentence please? Smile
The only issue I had was the socket size. 35 mm is not common and I could not get it in any local store. I helped myself with a 36 spanner and lined it with pieces of a 0.5 feeler gauge in three places. Best tip ever!
Posted 7th Dec 2016 at 00:31
35mm is very common, probably on 99% of psa vehicles on the road.
Nyloc type nuts are used to speed up service time on stage rallies
Posted 7th Dec 2016 at 10:15
miki4
Ah okay, now I understand. Thanks
Posted 7th Dec 2016 at 11:37
pugheaven
Down side is a nylon lock nut "should" be one time use only
Posted 10th Dec 2016 at 09:39
