displaying posts 26 to 41 of 41
Pages (2): 1 [2]
Author Subject: Mounting throttle bodies and setup
sergioiacobucci
Are you running a 205 rad there? I am getting the 118mm too so looks pretty tight!
Did you have a fitting for the vacuum hose that sits further down the standard inlet manifold?
Phase 1 silver track car
335i daily
Posted 28th Dec 2016 at 10:21
my inlet looks a bit shorter, and yes im in TH's not tb but still ran 90mm trumpets and a 125mm filter.
plenty of room as in nothing is touching Big grin
Posted 28th Dec 2016 at 10:39
blandy
No that's on the standard rad. I did get a different custom made rad later on as the bodies were covered up by the rad in standard location. If I were to do it again I'm a 306 I'd go for the 205 set up Like Welshpug.
I did manage to fit a stepped backplate and the narrowest pipercross filter (around 10-15mm clearance from trumpet face) which left around 25mm to the rad
Posted 28th Dec 2016 at 10:57
blandy
Ignore the yellow paint - that was when I was mocking up what size rad I wanted
And no I had no vacuum off inlet just strait from the pump to the servo (same now on my 205 as well)
Posted 28th Dec 2016 at 11:01
jorg
my setup with Satchell inlet and 118mm bodies
306 2.1 S16 Tarmac Rally Car
Posted 28th Dec 2016 at 11:16
sergioiacobucci
Thanks Blandy! Look like they were covered quite a bit but I think I am going to make a scoop up.
Jorg you look like you have so much more space! Love the back powder coated inlet, may have to copy that...did you run 8 injectors?
335i daily
Posted 28th Dec 2016 at 12:47
I had shorter Jenveys with my standard engine & had the same air filter as in this picture which has shorter jenveys supplied ....Tony Palfrey from Maxi Motorsport is amazing & does sell at reasonable prices ...
https://www.maximotorsport.com/products.php?directory=products/Satchell%20Engineering/Throttle%20Body%20Kits/XU%20kit
Posted 28th Dec 2016 at 12:59
sergioiacobucci
Thanks Damien. So they are not 118mm in Jorg's picture?
335i daily
Posted 28th Dec 2016 at 13:02
jorg
my bodies are 118mm but i have the same trumpets from the link Damien posted. can't remember what size the filter is, will have to look. no clearance issues as you can see and yes it is setup for 8 injectors but i am undecided what to use at the moment.
Posted 28th Dec 2016 at 13:44
sergioiacobucci
Post #35
Thanks Jorg. Ok i think the jenvey trumpets are quite a bit longer, still looks like it should be ok.
I think ill cut the slam panel out and create a scoop
335i daily
Posted 28th Dec 2016 at 14:39
Post #36
no need to cut the panel, you can go under it.
Posted 28th Dec 2016 at 14:58
blandy
Post #37
My manifold I have in my 205 is much more the one in Jorgs set up. My one in the pic was around 4years ago odd though as was a satchell inlet as miles did all the work but is much longer than any other I've seen
Posted 28th Dec 2016 at 16:34
sergioiacobucci
Post #38
OK that might make sense then.
WP - I'll see what looks tidy and go with that.
I have a load of other questions for you guys to see where you routed breather hoses etc or what you did with them.
335i daily
Posted 28th Dec 2016 at 18:25
grantpipe
Post #39
im using a jenvey inlet atm but want to change to satchell,does anyone know what they cost??
also dunno if it was mentioned about relocating the power steering pump aswell to be able to fit a filter and backing plate
Posted 29th Dec 2016 at 18:56
Post #40
£180 plus vat with an exchange inlet IIRC. around the same as a Jenvey inlet, but better.
Posted 29th Dec 2016 at 19:03
sergioiacobucci
Post #41
I heard you can squeeze it on without moving the PAS with a longer/satchell type inlet
335i daily
Posted 29th Dec 2016 at 19:09
Pages (2): 1 [2]
