Author Subject: Power Steering Pipes and Ram
Driving home from work yesterday, I completely lost power steering. Last time it was gradual caused by worn ram but this time was virtually instant. I put in 1 litre of fluid and it went almost immediately. I can't see any leaks under the bonnet so think it may be a rotted cooling pipe.
I'm going to get it on a ramp on Monday to have a good look. If rotted, I'll just cut out the rot and fit a hose to bridge the gap, but would like to fit a replacement.
Does anyone have any power steering pipes and a spare ram?
Posted 31st Dec 2016 at 13:54
barrym
speak to pug_306 mate, sure he will be able to help you out. Good luck with the diy fix if it's on the high pressure side!
Black Rallye occassional toy
Posted 31st Dec 2016 at 14:18
Is the cooling pipe with the pressure switch on the high pressure side?
Posted 1st Jan 2017 at 09:03
pug_306
The cooling pipe runs across the front of the car next to the radiator. The pipe that runs under the sump is the high pressure pipe ;-)
1992 205 GTi6
205 Turbo 340bhp
Posted 1st Jan 2017 at 09:07
mocinim
At a guess its probably the two short pipes at the ram they tend to rot
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 1st Jan 2017 at 11:28
Have you got any pipes in good condition?
Posted 1st Jan 2017 at 16:20
pug_306
I have good high pressure pipes not too sure on the cooler pipe i will double check on tuesday buddy
1992 205 GTi6
205 Turbo 340bhp
Posted 1st Jan 2017 at 20:55
I got it on the ramp and found that the undertray had worn down the high pressure pipe on the corner.
I have heard it rub on speed bumps, or could it be engine movement?
Posted 2nd Jan 2017 at 20:25
pug_306
Was all the bolts in that holds it too the engine ? I have a good one i can do for £30 inc del buddy
1992 205 GTi6
205 Turbo 340bhp
Posted 2nd Jan 2017 at 20:34
