Author Subject: HiSpec Calipers
jorg
HiSpec Rear SVA Billet Universal Lug (90mm PCD) Calipers:
These are new and unused. Billet 4 SVA90 calipers in black with 34.6mm pistons to suit a 22mm disc with built in handbrake system. come with the above set of pads. They are lug mounted (90mm) so will not fit directly to a 306.
http://www.hispeccalipers.co.uk/b4sva90.html
Looking for £250 delivered to Mainland UK
Ginetta 4 Pot Ultralite Calipers:
similiar to these: http://www.hispeccalipers.co.uk/ul4280.html
I would recommend a refurb with these calipers. They are radial mounted (130mm PCD) and have 34mm pistons. A used set of pads will be included. as you can see in the pictures the pad retaining clips have been replaced with bolts but the pads will still move freely.
Looking for £100 delivered to Mainland UK
HiSpec Ultralite 2 Ford Rear calipers:
in good condition, lug mounted (90mm) with 38mm pistons. they look to be setup to take a narrow disc (10mm max) but spacers are available from hispec if you wanted to use a wider disc.
http://www.hispeccalipers.co.uk/u2fr.html
Looking for £150 delivered to Mainland UK
If you have any questions or require any more pictures please just ask
Geoff
306 2.1 S16 Tarmac Rally Car
Posted 5th Jan 2017 at 16:52
Are the radial mounts on the hi specs the same as that of wilwoods
Ie would the brackets that were made in the group buy recently work with these?
Posted 7th Jan 2017 at 12:00
jorg
afraid not. these need a 130mm bracket, the Wilwood ones are 152mm
Posted 7th Jan 2017 at 12:11
Bahh cheers pal!
Are the brackets redily avalible anywhere?
Posted 7th Jan 2017 at 13:05
jorg
HiSpec did at one point sell universal brackets with different offsets, not sure if they still do though
Posted 7th Jan 2017 at 18:43
jorg
HiSpec Rear SVA Billet Universal Lug (90mm PCD) Calipers: SOLD
Posted 7th Jan 2017 at 23:07
jorg
pictures of the ginetta 4 pot radial mount calipers with a cyclone and 283mm gti6 front disc to give people an idea of clearance/brackets.
Posted 8th Jan 2017 at 16:55
dynacord
PM sent Smile
Posted 8th Jan 2017 at 20:26
jorg
Replied Smile
Posted 9th Jan 2017 at 08:39
jorg
Ginetta 4 Pot Ultralite Calipers: SOLD
Posted 9th Jan 2017 at 13:19
