Author Subject: Wheel bearings with track use
stevec33
Does anyone who runs a gti 6 on track struggle with wheek bearings? My car seems to ruin the nsf wheel bearing on every trackday i do! Is it possible something else is wrong or is this just what there like? Cheers
Posted 28th Feb 2017 at 20:05
quite likely a worn drive flange or poorly manufactured CV joint.
Posted 28th Feb 2017 at 20:49
fatlapit
Nah never had an issue.
Is the hub ok??
Posted 28th Feb 2017 at 22:23
miki4
Probably not the issue but unbalanced wheels put an unneccessary strain on the bearings at higher speeds.
Posted 1st Mar 2017 at 02:21
deeturbo
Are they being installed correctly?
I've seen a few people press bearings in via the middle race instead of the outer when pressing in to the hub.
Posted 1st Mar 2017 at 21:34
mocinim
Best guess is this if its that frequent
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 1st Mar 2017 at 21:45
stevec33
As far as i know all the surrounding parts are ok, I specifically asked it to all be checked out the second time. They have been replaced by two separate mechanics due to timing issues for getting it to a trackday so i would expect it to be unlikely for them both to get it wrong
Posted 2nd Mar 2017 at 12:28
The best most mechanics are going to do is have a quick look over it before they slap the bearing in. Get some verniers or bore gauges and check the hub and the upright.
Posted 2nd Mar 2017 at 12:51
stevec33
Gunna get it checked out more throughly this time, most likely to be the drive flange by the sound of it.
Posted 2nd Mar 2017 at 18:11
fatlapit
Id say the hubs goosed
Posted 2nd Mar 2017 at 20:45
cully
I killed a wheel bearing, wheel, droplink, tracking and two tyres at pugfest does that count?
Posted 4th Mar 2017 at 08:00
