Author Subject: Part number for floorpan crossmember/jacking point repair panel
Sprintevo
Both mine are rusted through so need replacing, ideally like to use a repair panel and ryan says Peugeot sell them, does nay one know the part number or correct term
Posted 31st May 2017 at 20:13
alcon
Everything to do with the floorpan is listed as NFP (No further production). That's not to say there aren't parts still hidden away on shelves up and down the country.
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 31st May 2017 at 21:06
pug_306
Last time I looked they wasn't available.
1992 205 GTi6
205 Turbo 340bhp
Posted 31st May 2017 at 21:12
Ben_W
Formerly gpm
Got part numbers boys?
Posted 31st May 2017 at 21:44
jord294
If you have the part number, I know someone who may be able to source new panels for you
Posted 31st May 2017 at 21:47
same as any other parts guy worth his salt
Posted 31st May 2017 at 22:54
mik
They are called 'stiffeners' IIRC. I priced them up in 2012 and they were expensive, over 250 quid for both sides for the parts. Eventually I got a competent fabricator to make and install new ones which look really good.
Cherry Rallye SOLD
Posted 1st Jun 2017 at 07:22
Sprintevo
I guess I will have to have them cut and fabricated in situ
Posted 1st Jun 2017 at 11:51
malo225
My car is away at the moment having these cut out repaired
By Zac in Hereford @ozonehostile
Posted 1st Jun 2017 at 15:48
Sprintevo
I have sourced a good 306 estate in my local scrappy - cutting them out and I have a good fabricator who will fix my floorpan. Its odd that this tiny section is so bad, the rest is tip top.
Posted 24th Jul 2017 at 16:08
fast_eddie
Can you put pics up please?
Posted 24th Jul 2017 at 23:38
Sprintevo
Scrapyard owner became akward, so I could not get under the car to cut them out. he would not put it on its side only onto a frame about 3 feet off the ground and the ground was really oily and wet, I suppose for the few pounds he would get for the bits he wasnt going to do much even though it was really quiet that morning.
Gong to clean up what I have and look to make some really good patches.
Posted 6th Aug 2017 at 08:58
