Rallye Race Car
| Author | Subject: Vacuum pipe size |
demondriverdan
Anyone happen to know the vacuum pipe size? To try and eliminate my issues I want to replace all the hose with newer stuff but am not going down to the car for a few weeks________________________________________ Rallye Race Car |
which bit?rare that they give any issues, most of it is a metal or hard plastic pipe and some pretty sturdy vac hose each end, its the plastic bit each end that people break are the weak points. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fatlapit
get rid of the pump you don't need it________________________________________ |
demondriverdan
Well I broke the plastic t-piece anyway so need to replace that.I have my pipes running a different way due to the bodies. The t-piece is much closer to servo with a long pipe running over the top of the engine from the vac pump and another, shorter bit from the inlet vacuum take off. I wondered if any of them were degraded and figured it must be cheap enough to get spare pipe and replace anyway? ________________________________________ Rallye Race Car |
you dont need the bit off the inlet, keep the pump and youll have less chance of vacuum leaks and more consistent brake assistance, bung the bit from the bulkhead straight on the pump.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
demondriverdan
If I do that then I need the pipe size even more to order a long enough pipe to connect it in one go ![]() ________________________________________ Rallye Race Car |
I took all my vac pipes of my servo & cam cover vac box & don't connect anything to anything & my brakes still pull my face off & don't fade |
demondriverdan
What did you use to seal up the inlet take off?________________________________________ Rallye Race Car |
i doubt he has one at all, neither do i as were on throttle bodies________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
demondriverdan
I'm on bodies as well but have a port on the manifold to connect a vacuum hose to?________________________________________ Rallye Race Car |
no need for it on a gti6 engine due to the vacuum pump.is it welded in or a brass takeoff? id either find a rubber bung or a screw in thing. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
