Author Subject: Coolant temperature
craig903
Hi, I'm not sure if this is normal or if there's something else going on, My coolant temperature gauge inside the car fluctuates quite a bit. The car doesn't overheat but when cruising on the motorway etc. Its down near 70 degrees and when stuck in traffic etc its up near 100 degrees.
Does this sound right?
208 GTI Owner
Posted 12th Sep 2017 at 23:05
demondriverdan
Yup, sounds about right, mine did exactly the same. In my new car I found it odd that the temp never moved!
Rallye Race Car
Posted 13th Sep 2017 at 09:33
marksorrento205
Both of mine sit just below 80 whilst driving and up to 100 when in traffic for a bit. If you think it's too low replace the thermostat for piece of mind.
Posted 13th Sep 2017 at 10:51
thermostat is 83 degrees so if it doesnt warm up past that in normal running I'd put a new one in.
Posted 13th Sep 2017 at 10:58
oliverharveyuk@hotmail.co.uk
Yeah mine hovers around 80ish when motorway/dual carriageway then creeps upto 95 in traffic fans kick in then drops to 90ish in rotation
98 Blaze 6 - Current
Posted 13th Sep 2017 at 12:37
Turbomark
Hi everyone, I recently started using my 6 and I noticed that when traveling through the hairpin bends without ever exceeding 3000 rpm the temperature is around 90, almost 100.
it's normal?
if I start using all the rpms will it stay between 90 and 100?
what would be the optimal temperature?
thanks a lot to everyone
Posted 30th Sep 2023 at 16:44
it's normal?
Hi,
The thermostat is an 83⁰c opening so it should sit just above 80⁰c when travelling freely and will rise in traffic etc as it is a "live gauge".
Yours is definitely too hot. Maybe the thermostat is stuck mainly closed.
I would remove it and test or buy a new one.
Stan.
Posted 30th Sep 2023 at 18:04
Turbomark
stan_306gti6 wrote:
it's normal?
Hi,
Stan.
traveling freely on the motorway or normally even on extra-urban roads it never exceeds 80 degrees.
if you force your hand you get to 90/100 but I haven't yet tried to do a special test at full throttle.
Posted 30th Sep 2023 at 22:16
