Would you all agree it's most likely the mounts ?
208 GTI OwnerTurbo'd '6 project - work in progress
| Author | Subject: Rear beam banging |
craig903
Regular Location: whitstable Registered: 08 Jul 2013 Posts: 273 Status: Offline |
I've got a banging noise coming from the rear passenger side when going over pot holes, bumps ect. It's a firm nock like the rear beam banging about so I'm guessing the mounts. I jacked the wheel up and can't feel any play in the trailing arm and the beam didn't feel loose but there was a bit of movement and a nock if I yanked on the wheel firmly. I tried to tighten the bolts in the boot floor but they weren't loose.Would you all agree it's most likely the mounts ? ________________________________________ 208 GTI OwnerTurbo'd '6 project - work in progress |
thats what I'd look at yrs.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jord294
Yep. More than likely mounts.Please don't waste your money on cheap pattern parts. Genuine are dear, but lemforder more affordable ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
ale624
Regular Location: bristol Registered: 02 May 2016 Posts: 180 Status: Offline |
Yep! my rear was doing the exact same thing for a while!Swapped both sets of mounts and i have not heard it since! Be careful if you intend to do this job yourself however! the rear beam is heavy and getting it lined back up with all the holes can be a bugger. watch you dont lift the car off your stands like i did! |
jord294
Consider refreshing the beam if you take it off car to do mounts.I can guarantee that if car has been previously lowered you won't get the bolts out to just change the mounts anyway ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
craig903
I believe it may be lowered I'm not sure. The beam seems untouched and I've checked the trailing arms for play and there's nothing. They spring lovely. Can you change the mounts with the beam in place or is it a take it off job?________________________________________ 208 GTI OwnerTurbo'd '6 project - work in progress |
jord294
You have to drop the beam________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
