Author Subject: Anyone know how to wire both fans together?
lurch86
Hello, while I am changing the radiator I thought it would be a good idea to sort the fans out. Anyone know a good way to make the fans both work together?
Wanted list... (P.m me if you have any)
Rollcage.
Strut Braces.
Lydden Hill 31/10/2015 Last Track day
1st time at Snetterton on the Bike! 22/08/2017
Posted 11th Oct 2017 at 14:38
scotzman
They do work together, or they should do.
Posted 11th Oct 2017 at 15:04
yes, they will do as standard, so you just need to fix them not bodge it up.
Posted 11th Oct 2017 at 15:50
lurch86
Well I had a fiddle with the relays and both fans kicked in. Strange thing is, when it was only 1 fan working that fan sounded like it was full speed. When the 2 work together it sounds like they're on half speed..? Perhaps they're meant to work like that in case 1 fails the other works faster to compensate? Anyway, new rad is in and bled and working well and the fans kick in and cool it down fast. Now for MOT and the next Track day, can't wait!!
Rollcage.
Strut Braces.
Posted 12th Oct 2017 at 09:29
demondriverdan
If they're in serial it might make sense that they run slower when both on
Rallye Race Car
Posted 12th Oct 2017 at 12:54
lurch86
Thanks. Hello Dan, How's the track car coming along? Been a while since I spoke to you?
Rollcage.
Strut Braces.
Posted 12th Oct 2017 at 13:20
the way they work typically is they switch from series to parallel to alter the speeds, so I would be replacing the relays and checking the contacts in the round plug on the fan cowling.
Posted 12th Oct 2017 at 18:01
lurch86
ok, Cheers. I'll look into it
Rollcage.
Strut Braces.
Posted 13th Oct 2017 at 10:02
tvrfan007
They work in half speed series for stage 1, then full speed parallel for stage 2. The fact only 1 fan runs at full speed on stage 2 tells you that the second fan is missing it's 12V feed. I had this on my HDi, and as Mei infers it was a corroded pin on the fan loom connector by the nearside chassis leg.
Fan wiring is available here:
http://www.peugeotlogic.com/workshop/wshtml/electric/ac306/coolfan2/fanop1.htm
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 25th Oct 2017 at 19:37
