As above I'm after the following shouldered bolt, number 2 on the diagram. They are no further production from Pug and someone has sheared my one!
Thanks
| Author | Subject: Power steering pump bolt |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
Hi,As above I'm after the following shouldered bolt, number 2 on the diagram. They are no further production from Pug and someone has sheared my one! Thanks |
alcon
Senior User Location: Glasgow Registered: 19 Jan 2005 Posts: 941 Status: Offline |
does anyone actually have number 6 fitted?.....I've never seen one.________________________________________ 1999 GTi-6 (china blue)1999 Rallye (black) |
woody.
Nope, not on mine. All about the weight saving |
quote: does anyone actually have number 6 fitted?.....I've never seen one. Love it.Apply back to black on mine the first Tuesday of each month. ________________________________________ ![]() |
alcon
These stupid things are still available from Pug as well.....for under a tenner!! Meanwhile, major parts and nuts/bolts for practically everything are NFP!!________________________________________ 1999 GTi-6 (china blue)1999 Rallye (black) |
alcon
Would no. 70 in the diagram not work if you cut a bit off the end?.....looks to be the same bolt as the elusive no. 2 but a bit longer, and its still available.________________________________________ 1999 GTi-6 (china blue)1999 Rallye (black) |
barrym
Senior User Location: Westcliff-on-sea Registered: 26 Jun 2014 Posts: 502 Status: Offline |
Are you sure it's NFP? It's still available for my VIN but mine is a Rallye. M8x1.25 length 35mm. part number 6913 S9________________________________________ China D Turbo HDi daily chargerBlack Rallye occassional toy |
woody.
The no. 2 bolt has a shoulder that locates in the pump bracket, I've measured it up and will get a sleeve made and use a standard m8 cap screw roughly 37mm in length (not sure why pug didn't do this in the first place)But yeah NFP for no. 2 which is 4007 N7. 6913 S9 is the no.70 screw as you've said |
woody.
Just to add some part numbers to the image in case anyone else needs them in future:![]() And a better pic of the mounting (this is alternator but you can see the bracket for power steering as well) ![]() |
miki4
Regular Location: Cologne Registered: 09 Nov 2015 Posts: 393 Status: Offline |
The black plastic piece number 6 is only fitted to phase 2's afaik. Have seen them myself.No idea on the bolt, sorry. |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
Mine made in early 1998 have the covers________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
the bolt is shouldered so you can fit one partially, drop it through the slot and it will stay in place whilst you faff with the other 3 bolts, you then do it up and the shoulder fits in the hole nicely.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
woody.
I've just sleeved that bolt instead, doesn't make it any harder to install tbh. For reference there's only 3 bolts that hold the power steering pump on, and the sleeve I used was 11.0 OD, clearance on the ID for an M8 Bolt so 8.10ish, and about 15.0ish in length. |
