Author Subject: Wiring diagram
jeffers Forum Admin
I’m looking for a copy of the engine bay wiring diagram if anyone has it? And before anyone says it yes I’ve done a search but the actual diagram doesn’t appear to be on here since photobucket decided to start charging. I’ve had a nose round the net and can’t seem to see it so wondered if anyone has a copy on here?
Thanks
Team Running Engine again!
Team Negative Camber!
Posted 8th Jan 2018 at 16:28
I’ve just texted ....Paul Vincent [CULLY] for you ...
He will have a look in a bit ...great bloke
He’s your man Thumbs up
Posted 8th Jan 2018 at 18:05
jeffers Forum Admin
quote:
[quote="Day666"]I’ve just asked Paul Vincent for you ...
Cheers Damo, you’re a Gent! Thumbs up
Posted 8th Jan 2018 at 18:03
cully
what do you want the wiring diagram for the engine loom or the layout drawing or both?
or what are you looking for specifically as the drawings arnt general drawings they are specific
Posted 8th Jan 2018 at 18:14
jeffers Forum Admin
I’m after the engine loom from the front inner wing upto and including the ecu plug and engine itself so I can identify rev counter feed, switched lives etc. Basically to wire an aftermarket ecu.
Posted 8th Jan 2018 at 18:17
cully
right ok that will be split over several pages probably,
have you the production code RPO number for the car?
ive added you on FB as it may be easyer to get info
Posted 8th Jan 2018 at 18:22
jeffers Forum Admin
quote:
[quote="cully"]right ok that will be split over several pages probably,
TBH I’m nowhere near the car as in around 200 miles away! Il messenger you matey!
Posted 8th Jan 2018 at 18:24
naah a single diagram will cover that,
http://www.306gti6.com/forum/showthread.php?id=150807
even if photobucket has stopped free hotlinking you can still find the images if you go to the image page.
this might be useful too as it has a pinout for the round plugs
https://www.205gtidrivers.com/forums/topic/114881-gti-6-engine-loom-wiring-guide-help-information/
Posted 8th Jan 2018 at 18:54
jeffers Forum Admin
quote:
[quote="welshpug!"]naah a single diagram will cover that,
Cheers Mei!Thumbs up
Posted 8th Jan 2018 at 18:55
cully
Posted 8th Jan 2018 at 19:29
thats a very usrful 9ne Cully, 1c02a and 1c02b are the two main loom plugs to the chassis legs.
Posted 8th Jan 2018 at 19:56
cully
Posted 8th Jan 2018 at 20:45
cully
chassis plug IC02A larger one Wink
pin 1 M444 permanent earth
pin 2 1070 Alternator warning light
pin 3 C120 Reverse light switch
pin 4 220 Reverse light switch
pin 5 CC1
pin 6 123 lambda switched live
pin 7 426 rev/tacho speed
pin 8 100 Starter motor switched live
pin 9 480 engine fault light
pin 10 400 Coolant temp gauge
pin 11 401 coolant temp gauge
pin 12 410 oil pressure warning light
pin 13 140 obd socket
pin 14 414 oil level gauge
pin 15 415 oil level gauge
pin 16 B155
pin 17 141 obd socket
pin 18 120 fuel pump switched live
pin 19 411 oil temp sender
pin 20 465 vehicle speed sensor
pin 21 427
pin 22 403 water in diesel feul detector info
pin 23 435 fuel gauge GPL info
Posted 8th Jan 2018 at 21:16
cully
Chassis plug IC02B smaller
pin 1 808 additional heating request
pin 2 8061 cooling water temperature unit command
pin 3 8055 air con regulation control
pin 4 1234 air con compressor relay control
pin 5
pin 6 8071 compressor cut off switch relay
pin 7
pin 8 820 IMMO signal
pin 9 821 IMMO signal
pin 10 822 fuel relay
pin 11
pin 12 109
pin 13 402 water level info
pin 14
Posted 8th Jan 2018 at 21:26
I knew Cully would come up trumps ...he’s always around helping everyone....hope we can pay him back one day ...top fellaThumbs up
Posted 8th Jan 2018 at 23:12
jeffers Forum Admin
Absolute legend Paul, thanks that’s a great help!
Posted 8th Jan 2018 at 21:55
fatlapit
Whats immo
Posted 8th Jan 2018 at 23:54
quote:
[quote="fatlapit"]Whats immo
Immobiliser Razz
Posted 9th Jan 2018 at 18:18
cully
immobiliser signal
its not a switch pair it is an encoded lock/unlock signal from the security box to the ecu
Posted 9th Jan 2018 at 11:37
quote:
Whats immo
In My Modest Opinion
  • Posted 9th Jan 2018 at 14:14
