displaying posts 26 to 50 of 106
Pages (5): 1 [2] 3 .. last
Author Subject: From daily drive to track car
jord294
You’ll have to take them studs back out if that’s the axle you’re pxing
Posted 11th Mar 2018 at 21:31
foot
Nah I’m PX the original one from the car but thank you 🙏🏻
Posted 11th Mar 2018 at 21:49
Fair play to you Tom lovely update m8 ..:keep um coming with plenty more pics Thumbs up
Posted 12th Mar 2018 at 17:01
foot
Will do! Work starting bright and early tomorrow 👌🏻
Posted 14th Mar 2018 at 09:53
foot
So yesterday went fairly well
started by removing most of the front of the car
Untitled by Tom Foot, on Flickr
no major rust on the front end which I'm very happy about
I have already removed the rest of the Aircon pipe work so don't worry they aren't staying cut off like they are in the photo here.
Both the condenser and the rad had seen better days so they are both heading for the bin
I then turned my interest over to re sealing the cam carriers as I've had a small but annoying oil leak from there
once that was all back together I started on getting the new front suspension fitted
Old
New
the old ones had started leaking and we also found that there was next to no rebound left in them so that would explain the terrible feeling at the front end.
so plans for tomorrow are
Second cam carrier re-seal and put engine back together
new Cam Belt on
Rallye Aux set up fitted
fit the new HiSpec callipers
install the new rad
install oil cooler
Posted 14th Mar 2018 at 10:15
99rallye
Making great progress! What brand are those front dampers?
Posted 14th Mar 2018 at 17:32
foot
Koni they are the STR.T kit. They aren’t really what I wanted to fit but i got the full kit so cheap I couldn’t turn it down
Posted 14th Mar 2018 at 17:45
blandy
Looking good what’s next on the agenda
Posted 14th Mar 2018 at 19:53
foot
new Cam Belt on
install the new rad
install oil cooler
Posted 14th Mar 2018 at 19:54
blandy
Post #35
Nice should be good fun when done
Posted 14th Mar 2018 at 20:02
foot
Post #36
I hope so! The car has been crap for a while which I’m not surprised at now due to looking at those shocks
Posted 14th Mar 2018 at 21:28
tvrfan007
Post #37
Great work chap, keep the updates coming. Smile
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 15th Mar 2018 at 06:46
foot
Post #38
heres a few photos from yesterdays progress
freshly sealed cam carrier
i was very happy with the internal condition of the engine with regards to the coolant water ways
plus while the top of the engine was off i managed to install a new heat shield
and finally managed to get the new brakes all installed, just need to bleed them now
Posted 16th Mar 2018 at 10:00
superchargedblack1997gti6
Post #39
Looks great mate, you will love those brakes
Posted 16th Mar 2018 at 10:26
foot
Post #40
yeah can't wait to try them out! I've had them serviced by HiSpec and just want to get it all finished now.
Posted 16th Mar 2018 at 17:44
foot
Post #41
got the engine all sealed back up
Also installed the Rallye Aux kit and mock installed the oil cooler. I will get some photos later this evening
Posted 16th Mar 2018 at 17:58
Cjwatson27
Post #42
Looking good mate, did you get that gold heat shield idea from that guy on YouTube rebuilding his lambo ?
Posted 16th Mar 2018 at 18:04
blandy
Post #43
Engine looks really clean looks like someone’s looked after it before
Posted 16th Mar 2018 at 18:57
tvrfan007
Post #44
Really good progress being made here. Good effort.
I can't even be arsed to service mine atm! Though I am currently on holiday..
I'm Si btw Tee hee
Posted 17th Mar 2018 at 11:24
foot
Post #45
quote:
[quote="tvrfan007"]Really good progress being made here. Good effort.
That’s no excuse I’ve taken a weeks annual leave to get this all sorted 😋
Posted 17th Mar 2018 at 11:27
foot
Post #46
Made more progress last night as managed to get the lower strut brace fitted, fitted the oil cooler however I need to now make some modifications to the bumper grill to make it fit comfortably.
Stripped the rear beam out of the car completely ready for the nfresh refereed one I’m collecting tomorrow.
Ran into a slight issue with the Cam Belt as the car had a 136 tooth kit fitted and Peugeot supplied me a 137 tooth kit so just need a few extra bolts and bits to fit that all up and finish everything
Posted 17th Mar 2018 at 11:31
Post #47
take the kit back and get the right one Thumbs up
Posted 17th Mar 2018 at 12:58
foot
Post #48
I would but Peugeot are apparently no longer supplying them. It took the kit i have 6 weeks to arrive from France
Posted 17th Mar 2018 at 15:16
Post #49
I'd call that a bit bo***cks but anyway GSF do Dayco kits at similar prices.
I wouldn't put a 137 kit inplace of 136.
Posted 18th Mar 2018 at 12:23
rich_w
Post #50
It's also worth noting the Dayco kits supplied through aftermarket channels such as Euros and GSF are not the same as an OEM Peugeot kit.
The belt is a different compound (OEM kit uses HSN- high temperature compound).
The tensioner is also subtly different and not of the same quality.
The idlers are the same.
I won't fit anything but Peugeot sourced kits.
Contact Details:
07732 822546
Posted 18th Mar 2018 at 22:58
