| Author | Subject: 2V on crank sensor, why?? |
Bakov
Newbie Location: Sofia Registered: 04 Aug 2018 Posts: 11 Status: Offline |
I have starting issue, on the sensor`s connector between pin 1 and 2/ 1 and 3 i have only 2V , autodata say 5V |
the 5v comes from the ecu, so you need to trace back through the loom and find where the problem is, the 5v out is shared with a few other sensors so its worth checking those as well, there are some splices in the loom where one larger wire splits to various components, its likely one of these is at fault.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Bakov
ah yes, forgot the crank sensor is separate.are the 12v supplies from the double relay all good? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Bakov
Yes, i have permanent 12V on pins 11,2,8,15,ignition ON - 12V on 14th. If i reconnect the double relay the first start is excellent. On the next i have issue, the relay is blocked from ECU and the engine starts hard, but always 2V on the sensor |
Bakov
Please tell me how to test camshaft sensor with multimeter, which terminals and what resistance should i have |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
Camshaft sensorpin 1 to 3 should see 5v ign on pin 2 to 3 should see 3.5-4.5V fluctuating with engine running at idle |
