Author Subject: Window mechanism issue
mellowr1
HELP!!!!! Trying to change window mechanism as mine stopped working. Attached is a picture of a nos part for mine on the left and my old one on the right,but it doesn't fit. Hits bottom of door when i try to line the top bolt up in the hole. Also the motors are different.
Any ideas as to if the new one is correct for GTI or what the old one is off? I know the car had a new door at sometime😔
Stuck now with no window mechanism fitted Sad
New on left & correct part number, old on right.
Motors
Old motor in situ
Posted 24th Apr 2020 at 21:59
There's two makes, I thick Bosch and Valeo.
I went to change mine and found an adapter cable for the different connector but the replacement screwed in okay.
Posted 24th Apr 2020 at 23:35
mellowr1
Unfortunately mine just won't seem to fitNo even though a genuine correct partSad the brackets on the 2 mechanisms look to be in totally different placesUnsure
Posted 25th Apr 2020 at 08:29
fair chance its the wrong assembly in the bag/box with how long these cars have been out of production, possibly a cab mechanism.
Posted 25th Apr 2020 at 08:59
mellowr1
It was from peugeot parts uk. I'd hope they would send correct partDunno wouldn't all 306 3 doors and mechanisms be the same be the same?Unsure
Posted 25th Apr 2020 at 09:05
that place used to be called Dean Hunter from memory, originally an oem peugeot parts distributor before peugeot bought it into one massive warehouse.
these days I think they buy up old stock from dealers, so its very possible the packaging got damaged or the label fell off.
306 cab windows are very different, they are frameless for a start! and have a quarter light.
Posted 25th Apr 2020 at 09:36
mellowr1
yep that's him, Dean.
The part number on the sealed bag is correct. Genuine peugeot label and part number.
As for the doors being the same i meant all 3 door door skins/internals with full window frame must have the same holes for mech to mount in?Dunno
God knows what is going on with it.Dunno
I'm just off outside to stare at it for another dayUnsure
Posted 25th Apr 2020 at 09:58
drop them an email with pics, quite evident its not right.
there were changes in assembly and brands but all the holes were in the same place, plugs changed, late ones were rivetted not bolted.
Posted 25th Apr 2020 at 10:25
mellowr1
I rang dean. He checked all part numbers and looked at pictures i supplied. He was going to check another door but i think i have cracked it now Thumbs up
Thank you for all your help guysThumbs up
Posted 25th Apr 2020 at 11:05
mellowr1
All fixed now thanks men. Goes up and down now and auto down works👍😎
Posted 25th Apr 2020 at 15:19
Thumbs up
Posted 25th Apr 2020 at 16:51
alcon
Well?....what was the outcome?....how did you crack it??
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 15th May 2020 at 19:11
